007 Lotus Submarine. 3D printed 1:10 scale
  • ffr2608
    • Oct 2009
    • 330
    Agreed. I spent 20 years at Toyota surfacing interiors and exteriors. In clay and on the screen. Neither was easy.
    DH
    • SteveNeill
      • 315
      Agreed on all counts. A printer is on the way here. I try not think about it much until it gets here. Thankfully I have worked for years with computers on all levels of 3D imaging mostly modeling in lighwave for film and TV which should help. Still I love working with my hands too and this model was entirely hand crafted, 66 inches long and built from my molds in epoxy glass. But on the next model I will print all the smaller stuff. It was a a pain to make the small parts for this model.
      Not to mention the second large mold here which was all hand built from styene and resin parts made from silicone waste molds. I own this model but it was made for an exhibit in San Francisco and was there for 6 months before they returned it. I had 6-7 weeks to build it from scratch. I nearly didn't make it. I can only imagine how much the printer would have helped here as I cut out millions of small parts to put on panels. Not to mention the windows cut into styrene.
      And Darrin there's that vacuum form machine in the BKG. It's a really good one and pulls flush to the bed every time. I want to try making a negative mold with panel lines and details and pull into that. The printer can print molds too I would imagine.
      • ffr2608
        • Oct 2009
        • 330
        Absolutely on the molds. How big is the vac-form machine "suck area"???
        • ffr2608
          • Oct 2009
          • 330
          Built the masters up last night and did a quick Ultracal30 plaster mold. Should be able to get at least 4 parts from these. Plan is to lay 1 up for a runner and eventually, 1 heavy layup with details for a display boat or ?????
          Happy with the results and will start sanding it out after a full day of curing. Need to knock down the door cuts and details.....Uggggh, Time to buy the fiberglass materials....
          DH
          • ffr2608
            • Oct 2009
            • 330
            Mold is cured and has several coats of PVA. Plan to lay up in the morning.
            • vital.spark
              • May 2010
              • 304
              As a past Lotus owner, I'd would like to purchase a set if you're willing to sell?
              • SteveNeill
                • 315
                Ultracal 30 the breakfast of champions! Darrin I will have to measure when I get in today but its about 19 x 14. It might be bigger. I'm planning a new Washington class boat I hope to vacuum form with it in three sections with reverse or negative molds.
                BTW I just heard from those people in China who wrote to me again saying my order has been delayed being shipped until the end of this month. I was surprised really. Evidently many people that were scammed by then did eventually get the machine. Time will tell.
                Wow this model is really looking good as usual Darrin!
                  • 3667
                  Darrin,
                  Great to see you back at it!
                  This is going to be fun to see this run.
                  Tom
                  • ffr2608
                    • Oct 2009
                    • 330
                    Not selling anything for the Lotus. Too much license stuff to be concerned with and after laying up that hull, I am done with glass for a while.
                    DH
                      • 1936
                      Steve,
                      Those models are fantastic! And again I am taken back by your work! Thanks for sharing those photos with us!
                      "firemen can stand the heat"
                      • ffr2608
                        • Oct 2009
                        • 330
                        Parts are pulled from the mold and rough trimmed. Lots of voids to deal with I have been through worse. Nice, heavy layup should reduce a bit of the spring out common with flat laminates.
                        • SteveNeill
                          • 315
                          Great Darrin this will shape up nicely.
                            • 2466
                            Did you mould that with polyester resin? Thought you tended to prefer epoxy.
                            • ffr2608
                              • Oct 2009
                              • 330
                              Polyester so I could take advantage of the gel coat surface. Lots of details on a car body and much easier to scribe lines in it after.
                              • ben1272
                                • May 2020
                                • 18
                                #30
                                May I ask why you did not simply use the printed parts for the sub?
