German type XVIIb
  • Monahan Steam Models
    Originally posted by MFR1964
    Nick,
    Running with compressor makes live easier, me like complex things.
    It's all about the journey of building and designing.
    Manfred,
    Yes, not a lot of room to fit all that gear but you did it! Much less room when you see your type VII in the background for comparison.
    I like your builds because you also enjoy the complex and you are absolutely correct that “It's all about the journey of building and designing.”
    Nick
    Romel,
    A similar system would not be possible, but the way i build the type XXIII uses the SD as a airtank for the SAS and those neat little LPB's do the trick for both raising the boat and scope/schnorkelmast.
    So in a way i've created the same, but on a much smaller scale, not with the same components i use at the type XVIi.
    Manfred
    would it be possible to put a similar system into the Bronco Type XXIII?
    Nick,
    There is not that much room as inside the type VII, i also jammed in the airtank and compressorsystem, this eats space, having no compressor is a option but if i can cram it inside it will be done.
    The forward space filled up very quickly. Every component has a place and the space was used efficiently. Nice work reducing the size of the servo switch assembly too. Looking really good!
    Servo steering is done, first compartment is done, pictures
    Started up the lathe and modified the servo steering, stacked all switches and made a contraption to hold them at their place, those stacked switches will control both valves and steering of the antenna.
    Had to remove the watercatcher first to create me some room to insert the servo, this watercatcher is placed to catch any water which will enter the inletfloat of the compressor, it has a sensor inside to give me a warning if i catch too many water.
    It slits in like this, just enough room to get it at it's place, holding it down with 2 sided tape.
    Builded back all components in reverse order, connectors not yet made.
    For now it's looking like this, all cables are still loose, first do some testing before i tie them down.
    From left to right, 2 servo's which control the torpedodoors, that print together with a not visible masterswitch controls the opening and closing of the torpedodoors and firing of the torpedo's, a linear servo for controlling that strange wing on top of the deck, watercatcher, modified servo with switches, compressor and a still loose E motor for driving the antenna-lift,.
    All components to build me the antenna arragement, antenna cable is soldered outside the boat and sealed with some 2 K epoxy-glue, remember a wire is a conduit, it will transport water, by interrupting it with a stud-connection or like i did you will stop this.
    The antenna-wire is routed by using those plastick tubes, placing her this way it will give you the maximum receiving, allways use plastick tubing, brass or copper will shield the antenna.
    Next compartment is on the list, together with completing the scope and schnorkelmast, stay tuned.
    Working on the wires which will bring the XVII to live,
    Placed the cables for controlling the servo's in, placed a 40 Mhz PCM receiver, and connected them, still have to program the transmittor to my needs, that servo with the microswitches eats too much room, have to rebuild that with the help of the lathe, those switches will be used for both activating the valves for diving,surfacing and steering of the future antenna's.
    All will be make-shift connections, more to see which things will work and what i have to change, at least i need to solder a new master-relais, the old one has not as much connections which i need,
    to the right you can see the water-alarm, this will be controlled by sensors allready placed inside near the keel and the inlet droplet collector used by the compressor, at the end it will steer the blow-airvalve and a buzzer to give notice of water inside the boat.
    For now. i've switch her on, all channels work as intended, the plan is to work from front to rear solving all problems while i'm working on her, first i have to start up the lathe to change the servo arragement controlling the micro-switches from horizontal to vertical, if all goes well she will fitt in exactly.
    Manfred,
    Tease away. That is an impressive micro fleet for sure. I will never get tired at admiring the work and details that this fleet has put into it.
    As for the resin Biber, it is the Verlinden 1/35 scale set. I also have the Verlinden Resin Seehund kit as well as the Bronco plastic Seehund kit.
    Nick
    Nick,
    Yeah, those are small gritters, just to tease some pics of my micro-fleet
    They really look small, question, that Biber your holding, is that a resin example?
    The XVII is coming along, busy with wires and components, l'm trying to fit things in, for sure have to alter some things, not that much room as with the type VII.
    Happy to see you back on this build. Nice progress you are making.
    BTW, I knew those Bibers were small and was impressed with the work that went into them but holy hell holding one in your hand really makes you realize how small they really are.
    Nick
    So, it's type XVII time, finished up the airsystem and did some testing to ensure it is holding up the airpressure.
    Click image for larger version  Name:	20220119_195653.jpg Views:	0 Size:	53.2 KB ID:	158597
    Click image for larger version  Name:	20220119_195658.jpg Views:	0 Size:	52.7 KB ID:	158598
    This i've shown before, there will be a signalside and a powerside in my boat, this will create less interference between all components, it will take some time before i've got this working.
    Click image for larger version  Name:	20220119_212916.jpg Views:	0 Size:	54.2 KB ID:	158599
    12 V compressor is mounted and connected, to the left you can see the red airtank underneath.
    Click image for larger version  Name:	20220119_212924.jpg Views:	0 Size:	54.5 KB ID:	158600
    Valves are in and connected, left it simple because room is a problem, just one valve for raising, and one valve for fine-tuning the dive, pretty much the same as in the Type VII.
    Click image for larger version  Name:	20220119_212928.jpg Views:	0 Size:	52.5 KB ID:	158601
    Made a connection to the ballasttank to blow the air in to surface.
    Click image for larger version  Name:	20220119_212954.jpg Views:	0 Size:	53.4 KB ID:	158602
    This is a selectorswitch for both the scope and schnorkelmast, to keep things simple i decided to steer them together.
    Click image for larger version  Name:	20220119_213017.jpg Views:	0 Size:	59.3 KB ID:	158603
    Those are the lines for raising and lowering the scope and schnorkelmast, placed restrictors to handle the up and down movement, they have to raise normal and not like a rocket.
    Click image for larger version  Name:	20220119_213031.jpg Views:	0 Size:	56.5 KB ID:	158604
    This i have done last summer, placed the contraption on the deck,did this to test if the boat was watertight, from left to right, float for managing the pressure, compressor and levelkeeper , next the float that will control the main valve of the ballasttank, scope, and schnorkelmast, the exhaust is functionable, that silicon hose is connected to the small dive valve,which allows me to trim the boat while submerged.
    Still has to finish up the scope and schnorkel, have to solder down some connections, did some pressure-tests, had some connectionsleaks, repared those and did some duration tests to see if the pressure will hold, main airtank has a pressure of 5 Atm, working pressure is turned down to 2 Atm,
    Next step is to build the electrical connections, get the cables of the servo's in and build up the boat in the rough, stay tuned.
    Thanks Ken,
    This was done last summer, this winter did some minor things on the boat, the rebuild of my house starts soon, so i don't think i can spent time inside the Cave, it has become a storage for all the stuff i had to remove downstairs.
    At the end of May i hope to start up with building up the Cave inside the new cellar, the positive side is, my Cave will 4 times that big, finally i can give all the tools on the attic a permanent place on the workbench.
    wow! Then the fun will begin and there will be (mostly) nothing to stop you!
    Thanks Ken,
  • Ken_NJ
    Good to see you back at it Manfred.
    Also a little update on the type XIIVb, she also smelled some water, a simple test to see if she was pressure tight, the testpool was allready in use for my Ko-Hyoteki.
    Ready to be plunged into the deep.
    She will need some weight from the internal stuff, only batteries inside and some valves, lead will be added inside the ballasttank if needed at a later stage.
    Pressing her underwater and blowing through the airline to build up pressure inside the hull.
    At very high pressure only this lipseal leaked, it will be replaced by a new one, you have to remember that the inside pressure will never be that high as simulated, in fact, i drive my boats pressure-less, due to use of a float on top of the deck, the pressure will allways equalize when coming to the surface.
