    Definitely need some crew members to show how cramped it was inside.
  • DrSchmidt
    Thanks, I also think that the lights really make a big difference.
  • neitosub
    Superb! The lighting makes me feel like walking through a museum exhibit!
    Nate
  • DrSchmidt
    For those who are on Instagram - the current status with lights on: https://www.instagram.com/reel/CguiH..._web_copy_link
  • goshawk823
    Worked a bit more on the details of the torpedo tubes. I installed the depth setting gears (blue arrow, port one is hidden). The running depth of the torpedos was set manually. Via a plate one could drive a shaft into the respective socket in the torpedo and then, via a hand crank, one could set the running depth. The gyro angle for the torpedos was set via gears (yellow arrows) and shafts via a hand crank below the gyro angle receiver (green arrow). The shooting solution was calcuulated using a "Torpedovorhalterechner" (torpedo data computer, red arrow). I also added the "Ausgleicharmaturen" (torpedo control panels, pink arrow), that were used to flood and vent the tubes. Via a angled adapter plate they were directly screwed onto the firing valves. The firing vales sat directly on the compressed air bottles. As a neat detail I added the hand crank, used to operate the muzzle doors and torpedo hatches, to the starboard torpedo hatch.
    Click image for larger version Name:	XXIII-234.jpeg Views:	0 Size:	68.3 KB ID:	163116
    Click image for larger version Name:	XXIII-235.jpeg Views:	0 Size:	63.2 KB ID:	163117
    Click image for larger version Name:	XXIII-237.jpeg Views:	0 Size:	63.2 KB ID:	163119
    Click image for larger version Name:	XXIII-236.jpeg Views:	0 Size:	66.8 KB ID:	163118
    the detail in this space is mind blowing. fantastic!
  • DrSchmidt
  • DrSchmidt
    The interior will go into a 1:35 Bronco XXIII kit
  • SSBN659
    Amazing work. Thanks for sharing it with us. I may have missed it earlier but what is the scale?
    Will Rogers
    SSBN659
    Mind blowing detail!
    That is awesome.
  • DrSchmidt
    Worked some on the torpedo tube assembly. Between the tubes and the pressure hull wall were two compressed air bottles that contained the air used to expell the torpedos. I installed both, but as the starboard bottle would have excessively blocked the view inside the torpedo room, I depicted it hollow and cut away. Like it allot!
ID:	162853Click image for larger version
ID:	162855Click image for larger version
    Insane... absolutely insane! So beautiful!
    Drooling like everyone else. When I see there is an update to this thread, I get excited to see what you are doing. Always impressive and fantastically detailed.
  • neitosub
    Stunning build!
  • goshawk823
    fantastic work on this boat. really appreciate you sharing the progress with the build.
