Thanks folks. There was little to none info about that storage space. So this is the realm of my fantasy. It's not finished yet. A bit more cargo and the ladder to climb down are still missing.Leave a comment:
If the inside is this good, the outside should be something to behold.Leave a comment:
Yeah, Nick. The good Doctor had me entranced with his radio-shack. But, the dry-goods space, adjacent the battery well.... That blew me away! So much like the spaces on submarines and ships I served on. I found myself looking for rat droppings and bugs -- the display is that good!Leave a comment:
The details you are adding to your build are amazing and really bring it all to life. My hats off to you sir! Great stuff!Leave a comment:
Little update...the racks in the storage compartment below the torpedo tubes are loaded:
1 Photo👍 1Leave a comment:
The finished result of the battery painting looks great. You must have done it without any caffeine in your system. Tedious work.Leave a comment:
The most repetitive part of this built is done....the batteries are painted. Next will be cabling and ventilation piping....
That's true, but if you short the busbar, it will give some nice firework, touching a busbar won't hurt you, even making connection with your body between two busbars won't give much trouble, as you stated, your body resistance is much too high to cause problems.
I agree, if you short a high power battery, it'll burn. But at 120 V your body won't be very effective at shorting a battery. 120V are potentially deadly but you're body has quite a high resistance.Leave a comment:
followed by a drunken whirl that lasted three days. Ah... Duval Street! (Thank God for penicillin!)Last edited by He Who Shall Not Be Named; 01-31-2022, 01:12 PM.Leave a comment:
Looking good David!
That had to be a very special day for you!
Guys, DC is more dangerous as AC, if you short a battery, you have a inferno, when you do this and the end you've got 120 Volts DC, and a massive current wil fry you, probably shoes left only.
Just my two cents.
Manfred.Leave a comment:
