  • DrSchmidt
    • Apr 2014
    • 1322
    #136
    I'll cut out windows.....
    • DrSchmidt
      • Apr 2014
      • 1322
      #137
      I'm mainly occupied doing sll parts right now. Here's an example including machine telegraph, rpm meter, the steering column of the rudder including a compass daughter, the secondary switchboard, an oxygen meter, lime cartridges, and a vent valve....
      Click image for larger version  Name:	XXIII-129.jpg Views:	0 Size:	56.6 KB ID:	157018
      On the ceiling of the control room, I've attached the feed through for the direction finder antennae and the corresponding drive. When the antennae was extended (hydraulics), a clutch cage connected to the feed through and the radio operator cold turn it using the manual drive in the radio cabin.
      Click image for larger version  Name:	XXIII-130.jpg Views:	0 Size:	54.7 KB ID:	157019
      Click image for larger version  Name:	XXIII-131.jpg Views:	0 Size:	58.0 KB ID:	157020
      • DrSchmidt
        • Apr 2014
        • 1322
        #138
        Continued with the curtain for the radio cabin. Found it as 3d file in the net, adjusted it to my demnds and printed it. The cirtain rail is made of 0,6 mm diameter brass and the curtain hooks out of 0,2 mm diameter copper wire. Attached it to the cabin that also got ist skirting baord made of styrene L-profiles....
        • goshawk823
          • Oct 2010
          • 260
          #139
          continue to be amazed by your work on this boat. fantastic!
          • Monahan Steam Models
            • 755
            #140
            Amazing work. I always look forward to seeing your build progress updates. Looking forward to seeing more!
            Nick
            • DrSchmidt
              • Apr 2014
              • 1322
              #141
              Thanks, I try my very best. Now that the firsts section starts to take shape my motivation gose up in parallel...thrilling to see things becoming real after over almost 2 years of research and design....
              Cheers Andreas
                • 755
                #142
                The research and your creation of the highly detailed 3D models was already impressive. Seeing that hard work now being transformed into actual components for this build as well as the quality of your finish work is absolutely impressive and a pleasure to be able to see. Thank you for sharing your awesome work!
                • goshawk823
                  • Oct 2010
                  • 260
                  #143
                  Andreas - between this Type XXIII and the Type VII you completed before this one, I'm wondering what your next detailed model like this will be?
                  • DrSchmidt
                    • Apr 2014
                    • 1322
                    #144
                    I once did a 1:72 scale Type II with interior. That was my start into scratch builing subs ith interior and layed tha foundation for the Type XXIII project:
                    As this first try was a bit coarse as I didn't have the skills, patience or my own 3D printer. So I'm up for a new, improved version. I bought the Special Navy 1:72 Vessikko kit and will get this done. Big advantage....tons of good phptos around. Muh easier than the XXIII. But let's alk about that in 1-2 years
                    • DrSchmidt
                      • Apr 2014
                      • 1322
                      #145
                      Adding bits and pieces to the control room. Ventialtion ducts, the steering column for the rudder, rpm meter, machine telegraph.....
                      • DrSchmidt
                        • Apr 2014
                        • 1322
                        #146
                        Started working on the lights of the control room. In 1:35 scale one an actually model the lamps close to the original, i.e. with base and cage for the bulb. I made 3D models of the base and the cage and printed a bunch of them. The wires of a warm-white micro LED is routed through the central hole in the base, and then the cage is glued onto the base. We have a lamp. Three of them went onto the pressure hull wall and I have to admit, that I'm rather pleaed wth the result....
ID:	157338Click image for larger version
                          • 3667
                          #147
                          Yes, like the lighting and the cages.
                          • goshawk823
                            • Oct 2010
                            • 260
                            #148
                            that compartment space looks so real, and the lighting is amazing.
                              • 1936
                              #149
                              Andreas,
                              I am at a loss for words! You are truly a master! I wish I knew of better words to describe what I am witnessing here. Your craftmanship is truly magnificent, I am just going to leave at that!
                              Thank you so much for sharing your work on this forum!
                              • DrSchmidt
                                • Apr 2014
                                • 1322
                                #150
                                Thanks allot. Still a very long way to go. I hope I can keep the rest at that level....
