Next mold dilema.
    • 12317
    Originally posted by 598602G
    Here is what I have so far on the sail. Using PE parts that I had on hand. Went with the double row of vents instead of the 4 rows of vents. I thought it looked better.
    looking good, Tim.
    • 598602G
      • Jan 2017
      • 500
      Almost done with Yankee sail. Camera just doesn't pick up all the detail I have in sail.
        • 12317
        Well … all right, then! Hope the root of my sail-planes match, Tim.
        • 598602G
          • Jan 2017
          • 500
          We have the same plans so I yes.
          • 598602G
            • Jan 2017
            • 500
            Started the scribe work on the Yankee. The surface coat of the epoxy and fiberglass powder is so hard I can barely scribe it with my scribe/jewelers file. Hopefully will have the Yankee hull scribe work done this week.
              • 12317
              Looking good, Tim!
              • 598602G
                • Jan 2017
                • 500
                Dave you get box with Foxtrot stuff in it? I should know better then to make boomers. Missiles doors are a pain. I will stick with SSGN's. Charlie II hull is almost all shaped. It is only 6" shorter then the Yankee.
                  • 12317
                  Got the box, have not opened it yet. Tonight, Tim.
                  • 598602G
                    • Jan 2017
                    • 500
                    Finally stupid Yankee missile hatches done. If I do one more boomer I will put a 357 Magnum to my head for a self made lobotomy.
                      • 12317
                      Good, clean job of it. Ain't scribing fun!!….
                      Put the gun down, step away from the table, and no one gets hurt!
                      • 598602G
                        • Jan 2017
                        • 500
                        Would rather die of lead poisoning then scribe. Go ahead make my day.
                        • 598602G
                          • Jan 2017
                          • 500
                          I am going to have to pass off the Yankee II to Dave. Just don't have the time anymore for all the builds. Only molds I have time for is the 1/72 Charlie II and the 1/72 688. The 688 is the fist to be molded next week.
