Next mold dilema.
    Originally posted by 598602G
    I am going to make split molds for the Yankee. Front and rears sections like i did the Delta III and IV molds. Easier to make the molds and easier to layup the hulls. Once I get the first hulls done I will just send you a complete boat. I was thinking I need a SD for my old SSY 1/48 type IX U-boat. I sent pics of it to Lee way back and he said it was one of his older boats before his gypsy crackhead glass layers. Have first layer on half the hull and 2 layers on the sail
    Tim,
    Any idea of the floodable volume needed in the ballast tank for that 1/48 Type-9 of yours? Give me that number and I'll put your SD together right away.
    OK, you send me that YANKEE hull and I'll chop off its stern and do my magic, the end result will be a hollow cast resin cone with attached vertical and horizontal stabilizers and stern tubes with encapsulated propeller shaft bushings. At that time I'll complete the sail planes and other control surfaces, propellers and other detail items. From all that I produce tools. Once I have my copies in hand I'll forward you all the tooling so you can get that kit into production. Sound good?
    • 598602G
      • Jan 2017
      • 518
      #62
      Sounds good to me. That U-boat is one heavy hull. I never made my hulls that heavy. So if I poured water in the hull and measured like how many gallons of water it takes to fill it up would that be OK?
      • 598602G
        • Jan 2017
        • 518
        #63
        I just filled the hull with water and it holds 3 gallons of water
          That gives us total displacement of a completely sealed up hull (plus the weight of the hull itself, which has a density of one). Not what I want. We want the displacement of just the above waterline portions of the hull. That includes the sail, masts, and gun(s).
          OK. Do this: weigh the deck and sail (GRP has a specific gravity close to one so there's a direct correlation of GRP weight to water weight) and give me that number. I'll multiply that number by 2.5 to account for the sides of the superstructure down to the limber holes, which is where the waterline is on the Type-7. That will give me the size of your ballast tank plus a healthy fudge-factor.
          So, get me that number and I'll take it from there, Tim.
          • 598602G
            • Jan 2017
            • 518
            #65
            Dave I got a fiberglass deck with the boat. I will to go to post office and have them weigh the and the wintergarden sail that I am going to use and send you the weight
              Perfect, Tim. God damit, man! Go to harbor freight, plunk fifteen-bucks on the counter and get one of those little digital scales. You cheap-skate, you!
              You give me that number and I'll to the magic here. Will a 3.75" diameter ballast tank fit in there and still not project above water in surfaced trim?
              • 598602G
                • Jan 2017
                • 518
                #67
                Not cheap just never had a need for a scale as I deal with premeasured fluids like for the epoxy resin. Or I have measuring cups. Anyway pic of the hull with a tape. Think by the time I install side rails to hold deck a 3.5" would be better but you make the call.
                  Yeah. We want plenty of annular space between SD and the inside of the hull for floatation foam. So, we'll go with the new thin-wall 3" Lexan for the ballast tank and 2.5 Lexan for the forward and after dry spaces.
                  Get me the weight on the deck and sail and we're off!
                  It'll look something like this:
                  • 598602G
                    • Jan 2017
                    • 518
                    #69
                    Dave I will try to get the weights you need today. Do you know any vendors that sell like resin parts or PE parts for the 1/48 type IX? I can hardly find squat for the IX. Lots of resin and PE stuff for a 1/48 type VII.
                      When you can, Tim. No rush. I don't have any Type-9 sources for you -- maybe those looking over our shoulder will provide you those resources. I would imagine a lot of commonality between Type-7 and Type-9 fittings, guns, and deck gear. I think Verlinden had some stuff at that scale -- don't even know if they are still in business or not.
                        I need to send my deck outline in to a guy in Germany, but working on a etched deck for that very same sub. Doing the long sail version.
                        • 598602G
                          • Jan 2017
                          • 518
                          #72
                          Sucks because most of wood decks, resin and pe parts are for VII's. For the deck on my IX think I will just custom do it in like basswod or teak. I have a Revell 1/72 type IX kit for reference, Thought about making hull molds for the 1/72 IX and make hulls out of glass but you didn't hear that from me.
                            I hope I heard that wrong, Tim. You're not thinking of pirating the Revell kit, are you?
                            • 598602G
                              • Jan 2017
                              • 518
                              #74
                              Not me. I just dug out my 1/72 type VII and type IX kits. Maybe a little small for my taste. Got my eye on a 1/48 type VII kit to get my grubby fingers on. Dave I am fixin to order the Foxtrot plans from Boris. How about I send you the file and you make a hardcopy for you in 1/72 and you mail me a hardcopy in 1/72 then we are on the same page.
                                Thanks for the clarification, Tim.
                                Sounds like a sound plan on the FOXTROT front. You do the FOXTROT hull and sail, I'll do the rest (most 'of the rest' is already done!)
