A Type XXIII in Ireland
    • 1645
    Rob,
    so you started with the XXIII, making some nice progress, like Tom said, it's a nice kit, fairly accurate to the original, as for the details, you can go wild or keep it moderate.
    One question, where did you get that prop?, looking forward to the rest of your build.
      • 3735
      A term we have used here is to Manfred something, which means detail the heck out of it. Like manfred asked, tell us about your prop!
      • The Boattrainman
        • Mar 2016
        • 443
        Thanks guys.
        Not going to do the full 'Manfred' on this one, just enough to lift it out of the ordinary.
        The prop is from the supplier below, Raboesch do all kinds props and types.
        Speaking of props, I'm going to do another 1/72 Revell Skipjack, anyone have a spare prop (very unusual design), willing to pay for postage and any other charges required.
        Raboesch 45mm M4 Threaded 3 Blade R/H Brass D-Type Propeller
        • The Boattrainman
          • Mar 2016
          • 443
          The prop is from Raboesch:-
          Supplier is Cornwall Model Boats, my favourite supplier, if I lived in the UK, I'd have the place haunted!
          Speaking of props, I'm going to do another 1/72 Revell Skipjack, anyone got a spare prop, very unusual design, willing to pay all charges, postages whatever to get one.
            • 2626
            Prop Shop are ace for propellers- investment cast rather than fabricated, and supplied in either silicone bronze, stainless steel or aluminium, tapped to a thread of your choice, balanced and polished. A huge range available, and I believe he does a 1/72 Skipjack prop. https://www.prop-shop.co.uk/prop-shop-store.php
              • 651
              Plus one for propshop, once I get in funds I’m going to need one for my skipjack
                • 13948
                Send me your mailing address and I'll fix you up. Just send back the shipping charge.
                • The Boattrainman
                  • Mar 2016
                  • 443
                  Dave,
                  Tried to PM you, it says you've exceeded your PM quota (whatever that is)!
                  Want to give you address details etc.
                    • 13948
                    Originally posted by The Boattrainman
                    Dave,
                    I don't do PM's, Rob. Here's my e-mail. I can box those up (and anything else you can think of) today and get it in the post tomorrow.
                    dmeriman@aol.com
                      I thought that Prop Shop had burned down? Are they back?
                        • 1645
                        Rob,
                        I will hunt that prop down at Rabousch, thanks for the tip, don't forget to paint it like steel, at the last period of the war they made them only in steel, just to save some brass for making other stuff.
                          • 13948
                          Originally posted by MFR1964
                          Rob,
                          Good point, and that white-metal propeller coming your way has that natural metallic 'metal' look to it already.
                          • The Boattrainman
                            • Mar 2016
                            • 443
                            Thanks David, you're a gent!
                            I drilled out the holes for the bollards all the way through to let air out as they are now hollow.
                            Click image for larger version  Name:	IMG_1966 (800x600).jpg Views:	2 Size:	246.7 KB ID:	131792Click image for larger version  Name:	IMG_1960 (800x600).jpg Views:	1 Size:	218.9 KB ID:	131793
                            I followed Manfred's advice and beefed up the deck planking with 1mm brass and also end stringers from 1.5mm x 0.5mm
                            Click image for larger version  Name:	IMG_1970 (800x600).jpg Views:	1 Size:	241.6 KB ID:	131794
                            I added the extra piece to lengthen the run of planks, here it is finished and under construction from strip styrene.
                            Click image for larger version  Name:	IMG_1962 (800x600).jpg Views:	1 Size:	252.8 KB ID:	131795Click image for larger version  Name:	IMG_1961 (800x600).jpg Views:	1 Size:	352.2 KB ID:	131796
                            I made sure the hull break was at the end of the initial run of planks and cut down a kit supplied item and then added the extra one near the tower so any tiny differences are not noticeable.
                            Click image for larger version  Name:	IMG_1966 (800x600).jpg Views:	2 Size:	246.7 KB ID:	131797Click image for larger version  Name:	IMG_1968 (800x600).jpg Views:	1 Size:	270.8 KB ID:	131798
                            The vulnerable cut down planking has reinforced ends on the single planks, they are sure to get whacked so extra strength is vital
Name:	IMG_1969 (800x600).jpg
                            The Boattrainman
                            • The Boattrainman
                              • Mar 2016
                              • 443
                              Nice turned scope from Wikinger.................
Name:	IMG_1971 (800x600).jpg
                              .........and the lift mechanism, closed cell foam and two shaft collars...............
Name:	IMG_1972 (800x600).jpg
                              ...........and in the raised position.
Name:	IMG_1973 (800x600).jpg
                              I found these 1.5mm tubes in my spares box, collars will be a nice feature.
Name:	IMG_1974 (800x600).jpg
                              The pins are soldered on top, won't install till the painting phase.
Name:	IMG_1975 (800x600).jpg
                              The Boattrainman
                              • The Boattrainman
                                • Mar 2016
                                • 443
                                #30
                                Question for the knowledgeable!
                                Does the XXIII have a rear white navigation light on the tower, also is the large centre hole on the front of the tower for a light, I hear most were removed.
