November Holiday
    That's the plan. We should end up with a tidy rear end, at last.
      Given that the waterline cut makes the upper and lower hull meeting so acute I'm wondering if I should do the same thing to the bow. Maybe cast the first eight inches or so as one piece and just drop that into the original mould and then add the remaining top section. I'll see how the stern goes before geiing ahead of myself.
      • DMTNT
        • Jun 2018
        • 297
        #333
        That may not be a bad idea. Curious to see how this works out with the stern. Keep us posted!
        Dead men tell no tales...
          The stern section came out OK. The seam is a little rough but will clean up with some filler and a bit of TLC. This is the rear section placed into the original lower hull mould with the gell coat in place for the new lay up. I think that it will be significantly better than the old version.
          • DMTNT
            • Jun 2018
            • 297
            #335
            I see what you're saying about the bow - that idea of making the first 8" or so one piece may not be a bad one. I think about what your eye gets drawn too immediately - the pointy bits, and if there's a big split running 'round the nose, even if it's really well done, you're going to notice it.
              I can probably make the seam go away; its just that there is a lot of detail there that might get lost in the process.
              • bwi 971
                • Jan 2015
                • 940
                #337
                Are you kidding me......I'm away for 5 months and and that period you built a complete november class.
                I like the way yoiu did the sonar dome........back to school moment for me.
                grtz,
                Bart
                "Samuel Smiles"
                  • Oct 2017
                  • 1118
                  #338
                  A nice video about K-3 `Leninski Komsomol`:
                    • 14009
                    #339
                    https://www.youtube.com/watch?v=E7Nhou7MtoE
                    Wow! Good catch, David. Thanks much. Lots of excellent eye-candy there.
                      • Oct 2017
                      • 1118
                      #340
                      Its been some time now... Any news?
                        Dave has agreed to take this one on once he's finished with other committments. Might actually turn out alright!
                          • Oct 2017
                          • 1118
                          #342
                          I understand correctly, Mr. Merriman will finish the kit and I may purchase it at Bob Martin's?
                            • 14009
                            #343
                            You got it. That's the plan.
                            In the interim, Bob is getting some other Soviet era r/c submarine kits to add to his ever expanding line: 1/96 SIERRA, 1/72 ALFA, 1/96 KILO (recently introduced), 1/72 VICTOR, 1/72 CHARLIE, and 1/96 SIERRA-2. List is not complete and is expanding as new, quality Master makers come on board. Kits being discussed include 1/72 FOXTROT, and 1/72 NOVEMBER and 1/96 ALFA.
                            Yes!..... that's right...... …… Bob and I are working overtime to make the local r/c boating pond safe for Communism (I'm in the wrong Party, apparently).
                              As part of my recovery plan I'm doing a bit of fiddling around with some unfinished work. Before I sold the farm and moved south I pulled a set of hull parts for the November and then sent everything to Mr Merriman. I kept that one set of hull castings and put them in a box that got lost with everything else during the move. Having finally got to the bottom of the pile of junk that turned up at my new house, I found these the other day.
                              Unfortunately there was a mouse problem somewhere along the way and the entire edge of the top side of the hull has been mouse toothed away. Little *******s weren't even very tidy about it either.
                              So in order to hide that god awful flange I have decided to add a conformal array along the entire side of the sub. Thus:
                              That stip is just a piece of epoxy laid up in the inside of a plastic pipe. It curves a bit too much at present but when its forced up against the lower hull side it should flex outward and make a nice tight join.
                              This is the new shed.
                              • Davidh
                                • Nov 2010
                                • 719
                                #345
                                Nice new shed Scott. Enough room for the chopper? Could you tell me the inner diameter that is most constant and how long it would be? Maybe a candidate for a ZB-2?
                                Dave.
