look forward to your solution!
November Holiday
Oh,oh,oh excited squeel. Propellers! They look great even without the dunce caps.
The third, and I hope, final answer to the forward sonar dome. This one is thin brass sheet beaten into submission and stuck to the front. I still have to refine the edges but it certainly looks a lot better.
That sonar window is beautiful. Please share with us riff-raff how you did it.
DavidWho is John Galt?Comment
Just curious, what is the sonar unit in the sail? It would appear that it rotates. I think I remember reading that our sets had to be “steered” as well. It is just interesting considering the multitude of different sonar arrays on & around the bow.Dead men tell no tales...Comment
It was an old practice to physically steer the receiving/transmitting 'beam' using a one or two axis turntable/gimble; the entire array moved. Nowadays the beam is formed mechanically (an armature) or electronically by selecting elements (transducers) of a fixed array for listening and/or transmitting.
DavidWho is John Galt?👍 1Comment
Impressed a thin sheet of brass over the nose to get the right shape; cut it to size; turned it over and scribed the back with a file; turned it the right way over and stuck it down. Turned out better than I thought it would and will probably look a lot better once I feather the edge around it and clean that up some more. More work on the sail today.👍 1Comment
If so, what was the surface you embossed over? And what's the gauge of the foil we see here?
Thanks Mate. That's a good shot. David: I mean scribed. Its .005" brass sheet. I used a bluntish file point to scribe the lines on the back side of the brass. What you see on the reverse is the pushed out scribe lines. I just laid the brass on a cutting matt so that the scribing didn't go too deep.👍 1Comment
Anything else I can do to help out with this project, Scott?
I'll have the SD's (mine and yours) worked out within two weeks of getting the hull -- need the hull to work out the topside displacement so I can plug that into the SD ballast tank design. I'm going with a two-motor 2.5" Lexan cylinder -- using mostly GATO SD parts.
NOVEMBER has been on my bucket-list since I first saw the thing in a (then) classified submarine ID booklet that one of the WEBSTER's navaguessers left on the chart-table unattended. I was standing watch at the BCP at the time and to break up the soul-crushing boredom of a patrol mid-watch, the OD had the messenger grab it and pass it around till everyone got an eye-full. Called it 'training'.
Forty-five years later and now that the cat's out of the bag (thank you Russian former crew and fan boys), we can have a credible looking model of this beast. I thank Scott for letting me contribute to this project.
