1/96 Albacore (after Phase III coversion 1961)
    • 13637
    #181
    Originally posted by DMTNT
    Perhaps a dumb question, but I've found that my aft dive plane control rod magnet de-coupling when I apply full throw on the servo. It'll still pull the rod attached to the aft planes, but the connection breaks until the servo returns to neutral and the magnets re-couple. Full throw in the opposite direction isn't an issue as the rod is being pushed.
    You're not alone there. It's happened to me. Either owing to some mechanical binding within the linkage or hydrodynamic forces from the control surface itself. The solution, as some have done is to go with bigger magnets that are less prone to de-coupling under tension. What I do is slip on a bent 'U'-shaped retainer clip that keeps the two magnets in close proximity, no mater how much tension is exerted to break union between magnet faces.
    • DMTNT
      • Jun 2018
      • 297
      #182
      I’ll look into that. My temporary solution has been to just join the offending pushrods with a brass collar and a set screw. Kills the quick-detach functionality, but it’s not going anywhere.
      -Brady
      Dead men tell no tales...
        • 13637
        #183
        -Brady
        That'll do it. But investigate why the magnet pull apart do to excessive tension -- something wroing with the linkage. Something is binding somewhere. Track it down and fix! Let's see some pictures of the linkages. Rudder, stern planes, and bow planes.
          • 3670
          #184
          If it is not binding, another area is that the throw of the servo is much.
            • 13637
            #185
              Look at that wee beastie. Magnificent job.
              • DMTNT
                • Jun 2018
                • 297
                #187
                Wow.
                I'd love to know what your choice of gray primer is.
                  • 13637
                  #188
                  Wow.
                  I use industrial grade fillers, putties and paints.
                  The DuPont automotive primers and paints are my favorites. Economical, chemically stable, tough, and well supported throughout the country. Nason gray primer is the one of choice today, as the old S31S just got too costly.
                  My favorite application tool is the old, nasty Paasche H-model, single-action spray gun. I'll occasionally use a big touch-up gun for the bigger work, and only rare occasions I'll make use of a double-action spray-brush.
                    • 13637
                    #189
                      • 13637
                      #190
                        • 13637
                        #191
                          • 3670
                          #192
                          What a boatload of information in these photos......Thank you.
                            • 13637
                            #193
                            • reddevil
                              • Jun 2009
                              • 346
                              #194
                              What a lesson of how to do things and arrange everything properly. Will remember and apply myself.
                                • 13637
                                #195
