Hello All,
After getting the top and bottom level and straight, I turned to dealing with the registration lip that would run around the inside of the lower hull and hold the top down. This is made from a strip of fibreglass that
is glued along the inside of the lower hull with the upper edge of the strip protrude about 3-4 mm above the edge of the lower hull. Once glued down I ran a file along the rim of the lower hull to smooth down any blobs of resin that may stop the upper hull from completely closing.
I once again used my customary bow assembly technique of gluing the lower hull at the bow to the top bow and using a small aluminium flat bar with a screw thread in it to secure the top and bottom hull sections and a lip in the rear of the upper hull to slide in under the back top hull section attached to the lower hull. This flat bar has to be glued onto the bottom bow section before the top and bottom can be glued together.
The bar points stern ward and aligns up with a hole drilled in the bottom of the lower hull that comprises the rest of the hull. I marked out a line, that runs from one side to the other, this will be where the lower cut will be made. I then glue the plate across the line. The will be cut out from underneath. I wrap the end with the solitary hole in sticky tape in order to make sure that the fibreglass does not stick to this end. Then I drill extra holes in the other end to allow the resin to flow all through the holes securing further, the front end.
Once this is done and glued securely , I then drilled the rearward hole with a smaller diameter hole that will act as a pilot later on for a larger one. Marking where the lower cut would line up with the top hull I then roughed up around the bow rim on top and bottom. I then secured down the top and bottom hull in just the right spot with tape and then glued the top and bottom section around the bow. I laid a thin strip of cloth and resin around the bow and let that set.
I would not glue the stern top section on till I get all the stern arrangements just right. This would involve aligning and setting the two stern shafts in place and making sure that the horizontal planes were installed aligned and with free movement. This would involve a fair bit of time and fine tuning to get right. I initially started with an aluminium bar that would be the support for both the shafts. I have made a thinner aluminium bracket that bolts down over the top with a single bolt in the middle. The shafts are dampened by having nitro silicon line sleeved over them to dampen vibration. More detail to follow next week.
David h
David h
