1/72 November?
  • 598602G
    • Jan 2017
    • 518
    1/72 November?
    Sadly a few weeks ago had to put my 91 year old mom in a nursing home. Have some time and some blue foam to scratch out a 1/72 November molds. Any interest in that boat and some kits? Don has the Golf II molds so if you guys want a Golf kit rattle Don's cage.
    • 13896
    Sorry about your Mom.
    NOVEMBER is a historically important boat. Yes!
    • Tirfing
      • Jan 2017
      • 66
      Building a November is a wonderful idea. A submarine much wished for, (was that correct English?).
      Tirfing
      • 598602G
        • Jan 2017
        • 518
        Sounds like proper English to me. I know a few guys are going to beat me up not making the November in 1/96 but O well. What I am going to do is make a split mold so I can make the front hull and stern separate. That way it will be easier and cheaper to make and ship. November will be 62 1/4" long with a 5" beam.
        • Tirfing
          • Jan 2017
          • 66
          Dividing the hull the way you are indicationg is probably a very wise idea. Mr Jaan Krak of Holland made his hull in a similar way.
          Maybe you have already seen this?
          WBR
          Tirfing
          • Tirfing
            • Jan 2017
            • 66
            Guys. Allow me to finish my evening by publishing a Picture i found on the net of a November (probably in scale 1/100) taking part in a junior challenge. Click image for larger version
            • Tirfing
              • Jan 2017
              • 66
Name:	627-November III-160710.jpg
              And Another one....
                1/72? Seriously? After all we've been through together? FIVE feet long? Have you lost the balance of your mind Mate?
                • 598602G
                  • Jan 2017
                  • 518
                  Scott look how cute the little 1/100 November looks in the pic above. You can barely see it
                  • 598602G
                    • Jan 2017
                    • 518
                    OK mate you get your wish. I did the math and at 1/96 the November comes in at 46 3/4" length. It will be much easier and cheaper for me to do it in 1/96. I have to go to post office today so I will see if I can ship a 6'x6'x48' box down under.
                    • Tirfing
                      • Jan 2017
                      • 66
                      In 1/96 it will be a thin boat. However as Zulu survives in 1/96 November should. However, dividing the hull the way you proposed can do the job of shortening a package.
                      • 598602G
                        • Jan 2017
                        • 518
                        More work to do a split mold. For you guys that live half way around the world I can always cut the stern and shorten box. Think guys is US would rather have a 2 piece hull instead of a 4 piece. I can make the hulls thick or thin.
                        • Tirfing
                          • Jan 2017
                          • 66
                          You probably mean that the US builders want a divided hull with an overside and an underside. Yes I can accept to get a 4 part hull. Then with a somewhat thicker hull.
                          • 598602G
                            • Jan 2017
                            • 518
                            Here are the drawings I am using. Got those out of a Russian warship magazine. 46 3/4" length. 3 1/2" beam. I will make the hulls as thick as I feel that everyone will be happy. Not going to custom make various thickness hulls. Won't happen. Everyone that has bought my boats in the past were happy with the thickness. This boat I will not make any of the resin cast pieces for the masts. I am on a time crunch here to get boat done as I may have to sell house for my moms care in a nursing home.
                            • 598602G
                              • Jan 2017
                              • 518
                              Here is the secret in how I make my hull pugs so fast. I glue 2 lengths of 3" blue foam together. Then I take some .060 abs sheet plastic and make the shape of the hull. Then I 3M 77 the sanding templates fore and aft then I start shaping. I use 4 sections of foam for the hull. 2 in the middle, bow and stern. When I have all the hull sections sanded to shape I glue them all together using the center line of the 2 sheets of foam a glued together. Then I glass the hull using a couple of layers and cloth. Fill and sand hull,primer paint and scribe detail.
