1/96 Soryu
ID:	110812Someting like this?
      • 13982
      Originally posted by HardRock
      [ATTACH=CONFIG]n110812[/ATTACH]Someting like this?
      Nope. This:
        Can't see your attachment
        • Peter W
          • May 2011
          • 511
          Stupid question.......again........but could you thin the tower down a bit ? Even down by 2 mm should help maybe ?
          Stupid out,
          Peter
            M - can't see the attachment but I now realise that I have to move the control horns. Peter: grinder at the ready - not stupid at all.
            • Davidh
              • Nov 2010
              • 719
              Scott,
              When I get a chance I can sent you pics of the mechanical mixer from Gotland
              Dave h
                Originally posted by Davidh
                Scott,
                Dave h
                Great. All ideas gratefully received.
ID:	110844Click image for larger version
ID:	110845Click image for larger version
ID:	110846Click image for larger version
ID:	110847Click image for larger version
ID:	110848 Got a bit carried away with the X-tail thingamy. This is the final version which, I am pleased to say, works. Along the way I learned about ojives, arcs and friction. Not very happy with the spring loaded ball joints which seem to be adding quite a lot of resistance to the whole set up. Unfortunately I could only fine two of the simpler snap on type. Now its back to the bat tub.
                    • 13982
                    Very quick work, Hardrock! Sorry about the attachment -- I'm an idiot.
                      Thanks Mate. I got the diagram - figured it out eventually.
ID:	110855Click image for larger version
ID:	110856Lookinh slightly more submarine like.
                          Looks like the Shinkansen...
                            Ha ha. Yes it does. Maybe they had some spare nose cones left over. Working on the periscopes today. The tallest one looks like a lava lamp on a stick.Click image for larger version
                              Last of the pretty photographs. The next lot will be post weathering, although all of the photographs that I have of these boats show them looking quite priastine. Perhaps a light touch is called for.Click image for larger version
ID:	110882Click image for larger version
ID:	110883Click image for larger version
                                "Priastine"???? I don't like auto correct very much but when it changes a correctly spelled word like "pristine" to priastine, I really have to wonder!
