RC Submarine Cylinder
    • Jan 2020
    • 1028
    Look up Silicone right angle or elbow connector for irrigation. Click image for larger version
    Cool!, yeah I went to plan "B", took pump apart, cut nipples shorter, epoxied fish aquarium elbows after resizing pump nipples.....
      • Jan 2020
      • 1028
      As I think I mentioned, I wanted to design a miter box to cut tubes. It has default 70MM, and has 18MM and 60MM inserts that screw in to threaded inserts. still need to mark cut line on tubes and rotate tube as I cut them. boxes screw to a level surface or 2x4, allows for varying lengths of tubes and has a solid insert that goes in first then whatever size insert to give tube a "stop" to prevent it from moving to the left, since I cut right handed. When cutting, will not use the grooves on the box, will use the outside edge of the box.
        • Jan 2020
        • 1028
        Ok, all sections printed, all tubes, wiring, electronics installed.. now programming the TX. I am nervous
          • Jan 2020
          • 1028
          Umm, forgot to shrink wrap pump terminals....
            • Jan 2020
            • 1028
            Everything works except the pump ESC, returning and ordered another
              • Jan 2020
              • 1028
              Update, ESC is working, had not stripped power in wires long enough to power block... now, all electronics working, all fits nicely inside the 70MM tube. Will have RX mounted at bow end, only had to run one positive and one negative wire from bow to stern. Will work on power supply wire lengths next
              • g2tiger
                • Sep 2008
                • 77
                WOW! looks real nice! I wants one :) Thanks for sharing.
                  • 2029
ID:	193854Watch your linkages. Cup seals work best when the action is true linear. What you have is a closely set servo that will swing through about 100degrees of arc, moving your rods outward as you reach the two endpoints. This will create binding. Typically if you're going with that sort of setup, you'd have an intermediate shaft that is hinged just before where it exits, letting the actual shaft run straight while the intermediate accepts the change in angle....
                    • Jan 2020
                    • 1028
                    Thanks! I will!
                      • 3658
                        • Jan 2020
                        • 1028
                        Thanks! This jogged my memory, I have these files.
