3D Akula running at Periscope depth utilizing 2.4 GHz
  • biggsgolf
    • Jan 2020
    • 1036
    3D Akula running at Periscope depth utilizing 2.4 GHz antenna in aluminum tube
    Nice depth control. Piston tank?
    • biggsgolf
      • Jan 2020
      • 1036
      Thanks!, no, one of Davids Cylinders, perfectly trimmed at full Ballast.
        You mentioned that you have the antenna in an aluminum tube. I assume (hope) that the actual antenna end is exposed and not enclosed. The aluminum can affect signal.
        • biggsgolf
          • Jan 2020
          • 1036
          Bob, yes the critical 1.25" extends above the aluminum tube, thanks!
            Are you using one of Bob's Depth Cruiser Modules? https://www.rc-submarine.com/product-page/depth-cruiser
            • biggsgolf
              • Jan 2020
              • 1036
              I am not, nor a Pitch Controller, all dive planes at neutral after submerged at full ballast.
                Wow! So just foam and weights?
                • biggsgolf
                  • Jan 2020
                  • 1036
                  yes, was inspired by this:
