1/120 Akula
  • mloo123
    Absolutely brilliant idea.
    Btw, may I know the size of the boxes you're using.
    thanks.
    Size used W80mm x H70mm. Length for the main compartment is 180mm. Length is not critical but W & H depending on how wide the beam of the sub. In this case the beam is 104mm ID.
    However, I find it's tough to get any smaller boxes than these as space within will be very constrain for any smaller sized subs.
  • vital.spark
    Just wondering how waterproof these boxes are for our use? Have you tested them to say a bottom of a 9' pool? I'm asking this for I would assume they were designed to keep rainwater out at atmospheric pressure.
    Originally posted by mloo123
    Some progress...
    Epoxy the rubber band hooks to the hull sides using home diy cable holder hooks cut into halves.
ID:	161300Click image for larger version
ID:	161301Click image for larger version
    thanks.
  • mloo123
    Some progress...
    Now that is a nice running place.
  • mloo123
    Wheel weights just in. Will properly trim boat this weekend. Click image for larger version
  • chaddivine
    Great Work!
  • mloo123
    Mloo123,
    ever considered using magnets to couple the servos and control rods together. The flat surface of the box lends itself to that.Click image for larger version
ID:	161184Click image for larger version
ID:	161185Click image for larger version
    Hi redboat219,
    Nice to see you here too. That magnet couple system looks sweet, especially if using them for forward or sail panes. Thanks for the tip!
  • James Wittaker
    This one is closer to the real Akula submarine...
    Akula submarine R/C model | 3D CAD Model Library | GrabCAD
    Mloo123,
  • mloo123
    Mloo123,
    May I know where you got the 3D files from. Thanks.
    Hi, you may find it here: https://blog.naver.com/tiver21/221817524156
    Point to note on the complete stern piece. It turned out approximately 2-3mm short facing towards the bow. Its better to modify the file before print.
    Mloo123,
  • mloo123
    Am modifiing the assembly jig currently to make shaft and plane installation easier. Am simultaniously switching between the PAPA and a large 1/50 Whiskey long bin. Need to set up my ZB 1/2, too. The build reports are always behind current state.
    Stay tuned for updates!
    Jörg
    Looking forward to...
  • mloo123
    Hi Das Boot,
    You can get these boxes for example here: https://www.aliexpress.com/item/4000852737997.html
    But im pretty sure you can get them cheaper in your local hardware shop, which i did for mine. Yes. a 1/96 scale boat should have enough room to fit them if they have a min 105-110mm ID beam width. i`m currently using 180 x 80 x 70 box for the engine compartment. Initially planned for direct 540size motor but changed to 380 geared for smaller footprint. These boxes will be perfect for twin screws boats like the Typhoon Papa and Oscar class submarines.
    And lastly, I haven`t decided how to securely mount the boxes onto the bottom hull yet. Its either the rubber band strap down or permanently epoxied methods. Cons for the latter is you can`t add additional port holes onto the box base for upgrades in the future tho.
  • mloo123
    Hi rwtdiver,
    Thanks for your comments.
    Its camera effects which makes the 3D hull looks good and in fact not so under the human eye...
    For the WTC, i found it`s much easier to work with!
