Le Triomphant
    I have a feeling the builder may post on this forum-
    Lots of interesting stuff over there, if you don't speak French, use the google translator.
    • solosub
      • 51
      • hello subculture :biggrin:
        No, Bernard (the modeler that makes this triomphant) it's a charming old man, but he not post on french submarine forums (scalesub, forumsousmarin, modelisme.com) ;)
      Laurent
      www.scalesub.com
      French RC submarine forum
      • solosub
        • 51
        Hi Guys :biggrin:
        For torpedoes, the battery is a micro lipo folded in three to enter in the tube. There are also smaller than 3.7 Volt Lipo batteries and 100 mA weighing 2 grams !
        Programming is done with a microprocessor for running time and it's a IR phototransistor that manages the start and stop the engine when the programmed time is over.
        The black tube in which the torpedo is used to protect the torpedo light when it is programmed.
        Laurent
        www.scalesub.com
          Folded Lipo? I thought bending Lipo batteries was a bad idea, how does he get away with that?
          • solosub
            • 51
            Langue source : français
            Saisissez du texte, l'adresse d'un site Web ou importez un document à traduire.
            Annuler
            I thought too, but he did it like that and it's no problem for now !
            Alpha
            Laurent
            www.scalesub.com
              This could power a 1/72 scale torpedo, http://en.m.wikipedia.org/wiki/AAAA_battery
                • 3770
                1/72 torpedo is a lot smaller in diameter. I like your thinking!
                Laurent, Thank you for getting that information! Merci beaucoup!
                • solosub
                  • 51
                  You welcome my friend :biggrin:
                  Laurent
                  www.scalesub.com
