The USS Skipjack - 1:72 scale WOW!
    David Merriman's conversion of the 1:72 Skipjack model.
    WOW!
    • 3377
    Who's the manufacturer of this 1/72 Skipjack model?
      • 13391
      It's a GRP kit I got from Lee Upshaw's, Scale Shipyard about fifteen years ago. Don't know if they're still available.
      However, the same subject, in the same scale, will soon be available as a proper styrene kit -- stay tuned, that announcement will be official in a few weeks. Caswell-Merriman already has worked up a SD for it and will have worked out an r/c conversion kit shortly after we get in a test shot.
        • 3377
        Wonder why they decided to have a nuke boat modeled in such a big scale? Not like pre-nuke boats with their cluttered decks and hull openings nukes have a rather bland appearance.
        Would you know if this model kit has internal detailing like the reactor, torpedo stations included?
          • 13391
          They based subject type on my recommendation and we'll see if I guessed right or not as these things hit the shelves. I initially pitched them 1/96 scale -- they figured bigger would be better, much to my joy.
          No internal detailing.
            • 651
            When i first saw the Skipjack's, its kind of so so, but when you take a step back, 1/72 scale is great because it's a relatively small nuke. then that big sail is gives great viz when running with the sail showing. All makes a lot of sense, make nice pairing with my Thresher, if you know what i mean
              I guess that's an incoming order then? :-)
                • 3377
                Can you give a ball park figure how much it'll cost?
                  • 13391
                  Between $1 - $1,000,000.00
                  Mike will do his best, as a retailer, to secure a reasonable discount, that's all I know for sure. Don't sweat it. If pricing is too much of a problem here, then I will suggest to you that you're in the wrong hobby!
                  You people!
                    • 651
                    Slow worker here, let me finish the Type VII, the M1, then get Foxtrot. If i feel like a simple job meantime i might ask production to re schedule :)
                    • Slats
                      • 1776
                      A great boat and a great video.
                      I am curious about the location your running in in the video. Is that a strong wind effect on the surface, or is what we are seeing the action of a swift tide?
                      Best
                      J
                      sigpic
                        • 13391
                        Wind..............
                          • 13391
                          Just got my test-shot from the manufacturer. With the kind permission of the Moebius staff, here it is:
                          behold!!!!!!
ID:	66656Click image for larger version
ID:	66657Click image for larger version
ID:	66659Click image for larger version
ID:	66660Click image for larger version
                            behold!!!!!!
                            Well! That's the last we see of HIM for a while! ( He hasn't had it 5 minutes and already he's drawing on it and stuff!)
                            He's like a kid in a toy shop! Pitiful really, but I'd be the same!
                              • 2405
                              Think European modellers will like to build it as a dry hull, and with the hull sections divided like that, it's spot on for a bayonet seal, but will the styrene hull be robust enough? Could always line it with epoxy inside I guess, or fit a tube.
                              That prop looks funny with the boss separate from the blades, what's the reasoning behind that?
