Working on an End Cap using magnets
    • 3769
    Wouldn't it be nice if we did not have to worry about seals? No cup seals, no bellows, and no o-rings?
    So I prototyped this and will be testing soon. (this is Nick's fault! just say'n - LOL)
    https://www.youtube.com/watch?v=DRDKM5qlv9I
    Examples of magnetically coupled linkages: Mast lifting systen - The Sub-drivers Forum (rc-sub.com)
      • 1658
      Nice Tom,
      Question, how high is the friction of the coupler to the propellorshaft, the sliding action is a clever move, did you measure the amount of pull?
        • 3769
        David, some of my thinking was from this. I certainly am building on your shoulders. Thank you! I may change the design of the pushrods for a more compact version. Using something similar to what you have used in the 1" tube. I can put the magnet horizontally and make a square tube that it slides in. I would rather have the tube going inwards rather than outwards for protection. Many ideas......First, I want to test this current design to get it to work. How will the nipples hold up with the spinning prop drive running on it? There is some interference of magnets between pushrod and drive. So, I just need to play.
        • Monahan Steam Models
          • 755
          Nice work Tom!
          Regarding the friction at the shaft connection. I always envisioned using a ball bearing type thrust bearing sandwiched between the bulkhead and the magnetic shaft coupler. The video that was floating around a while back of the submarine using a Tupperware container and lego components used a adhesive sided slippery film on the face where the magnetic part contacted the bulkhead. If the resin nipples don’t hold up to wear, maybe replace them with one made of metal like brass or stainless steel.
          Anyways, keep up the great work. Happy to see you having fun playing around with your magnetic design again. Still not my fault!!! LOL
          Nick
            I played with this years ago, but ended up shelving the idea. Primarily, I couldn't get a solid binding of linkage output to linkage that didn't jump a bit during actuation. Having full, precise, proportional control is pretty important.
            It's a good thought, for sure.
              • 3769
              Bob, me too, but applying “Home Improvement” mentality to this, the internal shaft connector and external shaft connector do not slip…….so far. I will keep you posted.
                Tom & Bob,
                Where is your go to source for this type magnets?
                Thanks,
                • Ken_NJ
                  • Sep 2014
                  • 1006
                  I get mine from K&J Magnetics. Always good to have many sources and they have a large variety to chose from. I usually order a variety of sizes at one time.
                  K&J Magnetics - Incredibly strong neodymium magnets at affordable prices. Large variety of stock rare earth magnets available.
                    Gaussboys Super Magnets - Neodymium Magnets and Rare Earth Magnets
Name:	DSCF4576 - Copy.JPG
ID:	157995Click image for larger version
ID:	157996Click image for larger version
ID:	157997Click image for larger version
                      • 3769
                      David, the klic-ons where did you source the threaded pieces with 1/16 on the other end?
                      I got my magnets same as Ken, K&J magnets.
                        Du-Bro. Part No. #111
                          • 3769
                          Thank you!
                            • 3769
                            Here is a video I should have posted a long time ago, but here was the test in the tub:
                            Now I needed to re-trim the sub. Added a small weight and placed it between its current location and the sail. Slowly moved it back (because the aft was light) until it leveled out and sank gently.
                            Click image for larger version  Name:	Skipjack_Trim_05.jpg Views:	0 Size:	39.6 KB ID:	162298
                            Moved the piston control (knob to the right) to just past 3/4s and got the sub to get a neutral or as close as possible neutral buoyancy.
                            Click image for larger version  Name:	Skipjack_Trim_06.jpg Views:	0 Size:	93.3 KB ID:	162300
                            Let the sub settle down to make sure the trim was good.
                            Click image for larger version  Name:	Skipjack_Trim_07.jpg Views:	0 Size:	50.3 KB ID:	162299
                            Click image for larger version  Name:	Skipjack_Trim_08.jpg Views:	0 Size:	45.2 KB ID:	162301
                            Brought the sub to the surface to check trim and It came out good.
                            Click image for larger version  Name:	Skipjack_Trim_09.jpg Views:	0 Size:	67.9 KB ID:	162297
                            Now get that weight affixed to the inside bottom of the hull and fix servo travel. Then get out to the river and film (David says no photos or film it did not happen).
