Gato Torpedo Door - Revell
  • Scott T
    • May 2009
    • 414
    Here is an idea for activating the doors on the Revell Gato model.
    Doors in closed position. Needs a little tweaking.
    Upper tube door open.
    Doors mounted to paper arms.
    These will be made from plastic with some type of hinge at folds
    Center door opened by pulling arm to rear.
    This arm mechanism pulls down the centerline.
    Scott T
    • 2040
    I like it! Very simple and easy to implement!
    • Scott T
      • May 2009
      • 414
      Some progress.
      Made a back plate to guide the arms.
Name:	small DSCN1463.jpg
      Made ramp to attach to door with holes to accept silicone glue.
Name:	small DSCN1469.jpg
      Put holes in back surface of door to
      glue into.
Name:	small DSCN1464.jpg
      Taped door into position to align for glueing.
Name:	small DSCN1467.jpg
      Door glued to pivot ramp.
Name:	small DSCN1472.jpg
      Found out ramp position did not work correctly.
      So I modified the ramp as seen in last picture then reinstalled.
      Door shown in closed then open position.
Name:	small DSCN1470.jpg
Name:	small DSCN1471.jpg
Name:	small DSCN1473.jpg
      • Scott T
        • May 2009
        • 414
        This illustration was found at Accurate model parts.http://amp.rokket.biz/am_1_72_gato_s...orshtspn-b-072
        So the plan is to activate the door in this motion which also will allow the addition of
        the torpedo tube door. If this does not pan out then I can use the idea already posted.
        This site also has accurized spoon and square doors.
        Scott T
          Hmm! Rather than use a stiff board to pull the door in and out ---
          Why not a weak spring to keep it out, and a string to pull it in. There would need to be a vertical rod for the string to go round. This would be placed in the center of the boat vertically. Both port and starboard strings could go round this pole/rod and straight to the servo.
            Or you could extend the length of the door forward, and then use a ram to shut it. Have the door pivot on a rod at the extension. The ram rod would go straight to the breach, so as it slid, the door opened.
            • Scott T
              • May 2009
              • 414
              I like these ideas. Maybe a combination of the ideas the hinge secured at the back and
              a string over the rod to pull it forward. So Kazzer what did you use to draw your illustrations?
              Scott T
                Scott T
                Mac Book Pro using 'PAGES' Mac's answer to MS Word
                • Sam Victory
                  • Sep 2021
                  • 391
ID:	163261Click image for larger version
