Rudder Actuation in close tolerance sterns, i.e. Type XXI, TXXIII style?
  • wlambing
    • Nov 2020
    • 385
    Might the fellows having built similar to the above in 1/72 scale, or smaller, share how they accomplished reliable rudder actuation in their projects? Pictures would be wonderful!! I have a 1/72 Foxtrot project going and am in need of a good system to make the turny-thing work! I did the work in a 1/35 Bronco Type XXIII, but there's a whole lot more room in that beast.
    TIA, Happy 4th!!
    Bill
    • 13641
ID:	162656Click image for larger version
ID:	162657Click image for larger version
ID:	162658Click image for larger version
ID:	162659Click image for larger version
      • 3475
      • wlambing
        • Nov 2020
        • 385
        Thank you!
        Bill
        • SubICman
          • Jun 2022
          • 87
          Bill,
          I have an idea on paper for using a robotics timing belt and pulleys. I also have a stainless chain from some old school radio gear that may work if I find the right size sprockets.
          • wlambing
            • Nov 2020
            • 385
            Cool, Tim! I have a bag full of plastic gears that was amongst Bob hoard of goodies. Something will work to make this happen!!
            Bill
              • 13641
              Bill
              You ham-fisted Idiot!
              Just throw a horn in there and be done with it!
              You Complexity Worshiping, knuckle-dragging A-Ganger types frost my ass! Who brought you up, anyway... Rub Goldberg???
ID:	162739Click image for larger version
ID:	162740Click image for larger version
ID:	162741Click image for larger version
ID:	162742Click image for larger version
ID:	162743Click image for larger version
ID:	162744Click image for larger version
ID:	162745Click image for larger version
ID:	162746Click image for larger version
ID:	162747Click image for larger version
              The Intolerant
              • wlambing
                • Nov 2020
                • 385
                Hey! Hey! Hey! I know exactly where these flat-tipped, stubby meat-grabbin' digits can go and what they can do! Had enough trouble getting a horn to work in the Type XXIII. I also know how much fun it is tryin' to use hot-metal glue to make teenie-weenie little horns without removing my fingerprints by accident!!! ;)
                  • 13641
                  • wlambing
                    • Nov 2020
                    • 385
                    Well, now I'm looking for a source for a teenie-tiny rack and pinion set up, suitable for use in only 3/16" of space. The smallest horn I have still will not clear the hull side and pivot the rudder stock (1/16" brass rod). I could cut a slot in the hull, or manufacture "blisters" for each side with a slot underneath for horn arm clearance, but that would destroy the fine lines of this racy looking subject. She's one of the RPM Tech 1/72 Foxtrot hulls, and a production hull that seems to differ greatly from the one HWSNBN built in some areas. Can anyone share a source for really small rack and pinion sets? Such info could be of benefit to us all for actuating little features. TIA.
                    Bill
                    PS- I did look at the Servo R&P Bob has, and it is too big also.
                    • wlambing
                      • Nov 2020
                      • 385
                      I found a small plastic rack and pinion set among some stuff from a friends estate. ID'd the pieces to use and will be making those pieces fit, post haste!
                        • 2506
                        You could draw a rack and pinion out in cad then have it 3d printed in nylon.
                        Or use a pair of small bevel gears, then you can the control shaft can use a rotary seal.
