I've decided!
    • 2848
    I've decided!
    Yes! I've decided! I am getting rid of all my STATIC DIVING SUB-DRIVERS.
    Why? Well, it occurred to me that I am half scared of losing boats in the canal, and with all the fangledness of WTCs generally, I felt the EASY Sub-driver was the best way forward - for me.
    I like the bigger boats! 4'- 6' long suits me fine, so all my little boats are going too. The light bulb came on and I realised that I only need to have one or two EASY SDs and I can run a fleet with them, by trimming each boat to suit the one Sub-driver. I don't even need a 6 ch radio to operate it.
    So! The other units have to go.
    I have several 3.5" SDs and a few 3" and 2.5", single and twin shaft. Many are fitted with Snort and or gas.
    Let me know if you're interested. These units will go at about half price, but each one will vary depending on the electronics fitted.
    Mike
  • subsailor
    • Feb 2013
    • 9
    Mike:What size is the 3.5"?Also price and approx. shipping to 02840. Thank you Chris
      • 2848
      I have several. What boat do you want it for?
        I would be interested in a twin screw 3.5" or a 3" and possiblly a little one for a type IX 1:72
        • type7
          • 154
          Hi Mike,
          I could use a 2.5" subdriver. Twin shaft preferred and longer is better if available. I can see putting the subdriver into several boats too. For instance: a Gato, Type 23, Victor, Type 9.
            • 2848
            Originally posted by type7
            Hi Mike,
ID:	92418Click image for larger version
ID:	92419Click image for larger version
ID:	92420Click image for larger version
ID:	92421Click image for larger version
            THIS IS A BRAND NEW SUB-DRIVER. 2.5" X 25" DESIGNED FOR REVELL GATO, M1 ETC.
            It's RTR and loaded. Mtroniks ESC, ADF, Sombra 8 ch receiver, Lipoguard, SAS system.All servos and push rods, one for fwd dive planes. All installed. All you need is a battery.
            Approx $750+ in value, but I'll let it go for $550 and free shipping in the USA
            SOLD!
            • type7
              • 154
              Mike,
              I'll take it. I am registered with Caswell, of course, but how do you want me to pay for it?
              Bob Eissler
                • 2848
                Mike,
                Bob Eissler
                PM coming to you.
                • subsailor
                  • Feb 2013
                  • 9
                  Hi Mike:Do you have 3.5 sub-driver for Moebius Skipjack and or Thresher 1/72 scale.Thank you Chris
                    • 2848
                    Yes!
                    It's almost new! I haven't used it much.
ID:	92423Click image for larger version
ID:	92424Click image for larger version
                    This is a SAS Sub-driver, all assembled by HWSNBN
                    It has a Sombra Receiver 8ch, Lipoguard, ADF, Snort Pump and controller, Mtroniks ESC. Shove a battery in and your off to the races- submarine races that is.
                    $550 - would cost you $750 + and you'd have to assemble it.
                      • 2848
                      I would be interested in a twin screw 3.5" or a 3" and possibly a little one for a type IX 1:72
                      I'm working the 3.5 one up. Someone refresh my memory on the Type IX please.
                      • george
                        • Dec 2010
                        • 727
                        Hey Mike
                        Do you have a WTC for the Revell 1/72 Type VII Not the newer model. I would even look at one with the ballast section BUT NO Ballast mech. Just ALL other electronics/motors in it. Would like to use the pressure cuff method.
                        George
                          • 2774
                          Mike,
                          How about just the 2" lexan tube less bulkheads and endcaps for the Type 7?
                            The type IX would be a long 2.5 with a blower/snort asperation system and at least the basic rudder/planes outputs. The 3.5 is going in the 3 large boats 1/24th and 1/32-35 scales. I too, have the idea to have interchangable drivers, for multiple boats. The 3.5 will slip right in all 3 of them, with some engineering. That one is the priority at this time. Is in the 3.5 that you are working up an sas, 2 shaft 2 motor, with the electronics kit? Im sure I will need several accuteriments such as batterypac, shaft connectors and such. Im sailing in uncharted waters here, but with a little help from y'all and Dr,"M" it should be a simple matter to get the row of ducks across the road without "gettin runned over, and torrup from the floorup" Pay Pal? or old spanish piece of 4 or 8 with certificate of origine by Mel Fisher,s Marritime museum as treasure from The Atochia ship wreck.
                              • 12370
                              So, that's why you're in the Key's!
