David Merriman's Garage Sale
    I went to see HWSNBN a couple of days ago and spent a day in The Cave looking at all those goodies, and then peeped into the back shed (few have entered this Aladdin's Cave) where David pointed out a pile of tubes he wanted to get rid of. He's short of space.
    So they went straight into the back of my car and I said I'd sort them out and offer them on the web. I may put some Sub-drivers on Ebay too.
    As you can see from the photo, there are several Sub-drivers in various stages of disrepair. I am going to find end caps etc and make each unit as complete as possible.
    If you just want a cylinder, then give me some dimensions and I'll try and sort one out for you, and will cost about $10 each. I'm thinking that complete units will run around $150 -200 depending on whats in them. I'll throw spare motors in free too. (We have lots!)
    I'll blow the dust off this stuff and gradually work through each good unit, then post more details, but if you see anything that takes your fancy now, just ask.
    What a find. Im sure that there are other goodies that you are not coming clean with. Comon.....what gives?
      • 3620
      You won't happen to have a 2" diameter lexan tube for the Revell 1/72 Type VII in there?
        Bob C asks ---
        Would be interested in a 3" tube , approx 20 to 24" long. If you had end-caps for it , great. It is for a 32 parallel xxiii sub. If there is one with ballast tank could you let me know the cost.
        I am not familiar with this model, so bear with me please.
        I have a 19" long, single shaft old style unit. It has a 4.25" long ballast tank.
        Spare 380 motor
        3 servos
        3 new push rod seals (not shown)
        1 new shaft seal 1/8" (not shown)
        There is a part of the equipment tray that has a rod attached to it. I think the idea was to mount the pitch controller in there so you could balance it. It had an old clockwork Subtek APC in there.
        $200
          All I have are these 2" offcuts.
          You could make the ballast bulkhead with a double seal, and add the battery compartment as a separate section.
            Here's a thought. I have this little 2" Sub-driver (goodness knows what it's for) and it's loaded with goodies like Mtroniks Speed Controller, Lipogard, Pitch Controller, Lepton 6 Receiver, 2 servos, all ready to run. The unit looks brand new.
            With a little ingenuity, and some more 2" tube, this could be a winner. A double seal bulkhead could be utilized to join the tubes.
              • 3620
              Just need plain tube about 18" long.
              Looks like it's about 4.5" long. Might be for a really short sub.
                11.5" and 6" ??
                  • 3620
                  Guess the 11.5" length will do.
                    OK
                    Pm me an address and I'll get the postage organised.
                    • george
                      • Dec 2010
                      • 731
                      Hey Mike
                      Any Sub drivers that might be a good fit for my Darnell X craft ? Also one for my WWII Japan Kaiten Suicide Submarine ? Or 1/69 Nautilus submarine??
                      George
                        • 2551
                        The 3.5" Alfa SD might be just the job if you're after making it a static diver. Ballast tank may be a little large, but you can always tweak that a bit with foam to suit.
                          Yep! Just tried it in mine and it's perfect!
                          It's all yours George.
                          • herrmill
                            • 360
                            Originally posted by Kazzer
                            11.5" and 6" ??
                            Reminds me of a funny cartoon I came across but probably best not post it here. Way OT!
                              Was the theme 'Size does matter!' ?
