Snort pumps
    • 3482
    Snort pumps
    Oh Mighty HWSNBN may I know the specs of the snort pumps you're using in your 2"-3" SD. I'm trying to locate a similary spec'ed pump online locally (shipped from China). In the past I use to see the same small pumps with square motor housings but nowadays they all come with 6v 0.25A 370 motors.
    • 2507
    Just google or eBay ‘Koge air pumps’ you’ll find lots of choice. Btw, 3 volt pumps work fine on 6 volts in my experience.
      • 1983
      pump info and specs are on my site under RC Components. www.nautilusdrydocks.com
        • 3482
        Thanks subculture. Found some 3v mini pumps. Take note that most lipo used on small boats packs 7.2v. Wouldn't these motors burn out fast?
          • 2507
          Unlikely. The pumps are lightly loaded so the motors don't draw much current.
