Best airbrush able clear coat?
    • Jan 2020
    • 1036
    For sealing enamel paint against water
    • 13976
    Any water-soluble acrylic -- the Cheap Walmart variety will work.
      Bruce,
ID:	187815 Click image for larger version
      My Nautilus was completely done with water base acrylics. David walked me through on how to use them not only airbrushing, but using paint brushes and a sponge. (thank you again David)
      "Firemen can stand the heat."
        • Jan 2020
        • 1036
        thanks guys!
          • 2639
          I thought you used 2k clearcoats, Dave. Or is that a bit too aggressive on enamels?
            • 13976
            If it is to be the final 'clear coat', yes, I would go with the two-part automotive system. But, as I read the question, he only wants a chemically stable barrier between the ever-touchy enamel chemistry base coat, and more chemically aggressive topcoats. In that capacity the quick drying, cheap water-soluble acrylic is fine.
              • Jan 2020
              • 1036
              To be clear, I want to use Revell Enamel on Type IX after priming. Then apply a clear coat to protect the enamel.
                • 13976
                Proceed.
                But for the life of me... I make the assumption that you are married to that god-awful system because those pricks have 'just the right color' you want. Not the hill you want to die on. If that's your means of section: Stupido!
                Buy white, black, clear, and the primary colors, a color-wheel and mix your own from a more friendly chemistry. Join us in the 21st-and-a-quarter-century, pal! Don't make me come over there!!!!!
                  Proceed.
                  Bruce,
                  Pay attention to the man!
Name:	AAA COLORS.jpg
                  These are the items that David had me get for both my Nautilus and my HL Hunley. With these colors you and with the help of the wheel you can concoct any color you want. Inexpensive water base acrylics and I use an acrylic clear coat.
                    • Jan 2020
                    • 1036
                    Bruce,
                    I know.... I have a color wheel, I will get those colors and try again, thanks for the help.
                      • Jan 2020
                      • 1036
                      Might be a good DiveTribe topic?
                        • 13976
                        Yes. A basic need: to preserve, color, and weather. Start a series -- jumping in with the virtues and liabilities of the many paint chemistries out there -- it being a broad, many faceted subject.
