Servo connections in the wet
    • 3622
    How do you seal the connector from water ingress?
    • 13842
    By keeping them in the dry. Duh!
      • 3622
      Didn't you put 2 brushed motors in the wet with your 1/96 Type XXI? Duh!
        • Oct 2017
        • 1019
        3 Bolt studs through the bulkhead, receiver end in the dry, cut cable, make connection to the servo-end of the cable in the wet, seal with silicone.
        Nothing new....
          • 13842
          electric motors are dumb simple and robust. Servos are smart and picky.
