Motor Shaft to Prop Shaft
    • Jan 2020
    • 1036
    My shafts do not align. The motor shafts (5MM) are below and inside the Prop shafts (3MM). I can make longer Dog Bones and move the Cylinder forward of center, but looking for alternate ways to make the connections. Disregard the center shaft with the notch in the photo. Thanks for ideas.Click image for larger version
    • Oct 2017
    • 1108
    Raboesh-couplers and intermediate shaft? Thats what i do.
    • type7
      • 198
      Shorten the prop shaft. Cut a dog bone in half and lengthen it to make it into an intermediate shaft.
        • Jan 2020
        • 1036
        Yeah, aware of that technique, the angles are too much.
          Lego or Tamiya universal joint Click image for larger version
ID:	186059 Click image for larger version
ID:	186058 Click image for larger version
            • Jan 2020
            • 1036
            Amazing! Thanks so much! I can re create and print correct size!
              STL files https://www.instructables.com/WiFi-Paddle-Boat-II/
                • Jan 2020
                • 1036
                working on it! Click image for larger version
                  • Jan 2020
                  • 1036
                  Cool, trying it too Click image for larger version
Name:	Image 2-14-25 at 9.52 AM.jpg
                    • 2642
                    I prefer to avoid cardan couplings they always give vibration unless perfectly aligned as they’re not a constant velocity design. You can purchase really nice stainless steel CV shafts in all sorts of sizes online, however they’ll nearly always be metric sized, so bear that mind if you’re using imperial sized shafts.
                      • Jan 2020
                      • 1036
                      Thanks for that!
                        • Jan 2020
                        • 1036
                        Bob posted a video on this operation:
