Can the R&R set up with an internal cylinder be converted into a LPB/Snort?
The float activated vaccum relief valve is converted into vent valve using a NC solenoid valve ( V).
An open pipe connected to the outside to serves as a water intake /exit.
A snorkel (S) connected to an airpump (P) is used to blow ballast.
