I can do that. I guess my bigger question is whether I even got that alignment right on my picture? It would mean the pump goes from a horizontal position to a vertical. What's also tricky are the long air connectors the pump comes with: I will end up bending them to either side, not ideal but possibly the only way to install?
DOA Neptune SB1 Tiger Thunder Seawolf - need some help
I managed to disassemble the boat, remove the old pump and got the new one ready. But I'm struggling following your directions on how to install the new pump. If you have any pictures of the pump as it sits in your boat that would be helpful. I don't know which direction it is facing etc. Trying to mount it vertically but there's not enough room as it bumps against the board of the servo connectors.Comment
Here is the source for the tubing:https://www.amazon.com/gp/product/B0...e?ie=UTF8&th=1Of the approximately 40,000 men who served on U-boats in WWII, it is estimated that around 28,000 to 30,000 lost their lives.Comment
I need to make a correction about the tubing. It looks like I used 3/16 x 5/16: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
apologies, Tubing is a consumable on roller pumps so get used to replacing at least seasonally.Comment
I managed to disassemble the boat, remove the old pump and got the new one ready. But I'm struggling following your directions on how to install the new pump. If you have any pictures of the pump as it sits in your boat that would be helpful. I don't know which direction it is facing etc. Trying to mount it vertically but there's not enough room as it bumps against the board of the servo connectors.1 Photo👍 1Comment
Don't distract me now.Comment
Scary.Comment
👍 1Comment
English is my second language so I often struggle finding the right word for stuff like that. Which makes searching for it on amazon equally difficult.
That said I noticed on the Amazon page you linked there are a bunch of the connectors and Y linkages listed when scrolling down.Last edited by tifosi12; 09-18-2024, 12:16 PM.Comment
