Attaching and Sealing Control Rod Bellows
  • biggsgolf
    • Jan 2020
    • 1036
    Hi all,
    What is the best glue/epoxy to attach Bellows to control rods?
    Thanks!
  • neitosub
    • Nov 2021
    • 163
    I just run my linkage rods through the bellows and let friction hold them in place. The hole in the rubber bellow is so tight that it grips the rod and forms a water tight seal.
    Nate
      Rtv silicone on the inside + small cable zip tie outside.
