Anybody tried using 2.4ghz with a towed buoy?
    • 3409
    AN/BSQ-5 Towed Buoy Click image for larger version
    • 1959
    Many have talked about it, but no one has implemented it that I'm aware of. I can't see the advantage, personally. Towing a cable affects the performance of the boat and would be exceptionally prone to fouling by your own prop and other craft in the vicinity. On the plus size, I guess you'd have a floating emergency buoy in case of catastrophic flooding...
    To each their own. If it sounds good to you, make it happen!
      • 3409
      David's 1/96 Blueback with towed 808 camera housing. Click image for larger version
ID:	150976Click image for larger version
        • 13525
        It's an ugly, cumbersome, awkward, useless arrangement to get signal to/from your boat.
        If it ain't broke, DON'T FIX IT!!!
        God put masts atop the damned things sail for a very good reason. Use them! That's where your data-link antenna goes. Not on some loathsome, ugly fishing bobber trailing a nasty piece of coaxial cable!
ID:	150982Click image for larger version
ID:	150983Click image for larger version
ID:	150985Click image for larger version
ID:	150986Click image for larger version
ID:	150987Click image for larger version
ID:	150988Click image for larger version
ID:	150989Click image for larger version
        The only tow I'll ever use is to get pretty pictures.
ID:	150979Click image for larger version
          • 13525
          Furthermore!!!
Name:	DSCF2476 - Copy.JPG
ID:	150994Click image for larger version
ID:	150996Click image for larger version
ID:	150997Click image for larger version
ID:	150998Click image for larger version
ID:	150999Click image for larger version
ID:	151000Click image for larger version
ID:	151001Click image for larger version
ID:	151002Click image for larger version
ID:	151003Click image for larger version
