Shaping Foam
    • Jan 2020
    • 1027
    Shaping Foam
    What is tge best way to shape foam to match the hull curve?
  • Bob Gato
    • 873
    I don't know if you can adapt this method to what you are trying to cut but I use aluminum building .005" flashing for forms to follow with a hotwire (easily made from a lighting dimmer and a doorbell transformer and some ss wire) If the forms don't work for you- you can freehand cut-clean and easy...these two pages show my making of two CRRCs for my Navy Seal SOC...I've made several masters for fiberglass hulls using this method-it not only cuts the foam -it cuts time!
    https://www.rcgroups.com/forums/show...&postcount=217
    https://www.rcgroups.com/forums/showpost.php?p=41032455&postcount=218
    • Bob Gato
      • 873
      Sorry-that last link didn't work out-so I opted to go the additional post as I was surely out of edits!
      https://www.rcgroups.com/forums/show...&postcount=218
      Click image for larger version  Name:	P2150044.jpg Views:	0 Size:	75.4 KB ID:	148361Click image for larger version  Name:	P2030031.jpg Views:	0 Size:	51.1 KB ID:	148362
        • Jan 2020
        • 1027
        I am referring to flotation trimming foam at the waterline which is placed oh the curved lower Click image for larger version
          • 1993
          I simply use a band saw and then sand to shape. Works like a champ!
            • Jan 2020
            • 1027
            That sounds good!
            • coryhenry
              • Jul 2020
              • 156
              I agree I just sand, it goes really quickly.
                • Jan 2020
                • 1027
                Thanks guys
                  • 3681
                  I learned to put vertical cuts in my foam to allow air trapped between the foam and hull to escape. I had a sub that would trim correctly, but if I waited awhile and came back to it, it would be sitting lower in the water. The best theory I could come up with is trapped air. David recommended putting channels in to allow any trapped air to escape.
                    • Jan 2020
                    • 1027
                    I totally love that you brought that up. I have noticed that my first sub would be perfectly trimmed, but would change, perhaps ghis is why.
                    • Bob Gato
                      • 873
                      Just throwing this out there-there is foam and there is foam-some is closed cell and some is open cell otherwise known as a sponge ..I don't really know what you are using-but stay away from the white polyurethane shipping foam. Your best bet is pink or green styrene construction foam from big box home stores...
                        • Jan 2020
                        • 1027
                        Yes, I use the green closed cell, thx for bringing it up,
                          • 3681
                          Mine is the closed cell pink stuff, good point Bob!
