Heavy Duty Remote On/Off Switch
    • Jan 2020
    • 987
    Has anyone experienced lipo drain if lipo is left wired to the Remote On/Off switch from Drydocks even when remote is turned off? I left it wired for two days and my lipo drained below the rechargeable rate minimum. I was able to charge at a lower rate but it is no longer balanced. I realize it should not be left wired when not in use, but wondering what I could wire inbetween the remote receiver and the lipo to stop the discharge.
  • secrtwpn
    • Feb 2012
    • 182
    How did you hook it up? I have one too.....
      • Jan 2020
      • 987
        • Jan 2020
        • 987
        I ran the red & black wires to lipo, the other black wire and the white wires to the ESC
        • Bob Gato
          • 873
          Is that a remote on/off with a key fob? if so the battery always powers the receiver in the switch-although it will use very little power...it should be disconnected at the end of the day. If it doesn't have a key fob transmitter...then nevermind -BG
            • Jan 2020
            • 987
            Thanks Bob, yes a key fob
            • Bob Gato
              • 873
              ... I realize it should not be left wired when not in use, but wondering what I could wire in between the remote receiver and the lipo to stop the discharge.
              All I could say about anything you could put in between the the remote and the battery is an open circuit...considering the low amperage drawn by the remote switch,you could install a normally closed magnetic reed switch to supply the power for the receiver only( not the supply for the load) At the end of the day you could drop a magnet next to the switch capsule and open that circuit. Kind of redundant though -I would just disconnect the battery..especially a lipo-which needs to be charged or discharged back to storage charge levels when not in use...and you DON'T want to do that in the sub (the model submarine does not make for a good fireproof charging container) -also note that a magnetic reed switch is good for only a very low amperage.
                • Jan 2020
                • 987
                Agreed! Thanks, I have a curious mind, lol
                  • 1959
                  Of course it drains the battery. It needs to listen for signal, and therefore needs to be "awake". Current draw is miniscule... something like 20 or 30 mA, but it's there.
                  • Bob Gato
                    • 873
                    Don't look at the remote switch as an on-off switch , consider it an arm-disarm switch...
                      • Jan 2020
                      • 987
                      Thanks Bob G
                        • 3666
                        Thanks Bob G
                        That is the best description I have heard for this. I will be using that to explain these!
