Warcraft II Gnomish Submarine / Giant Turtle
  • TuptubBuilder
    • 131
    That form factor makes it an interesting packaging challenge, IMHO. I look forward to your updates.
    • NicholasRadzykewycz
      • Aug 2025
      • 35
      Click image for larger version  Name:	Advanced textures2.jpg Views:	0 Size:	57.8 KB ID:	190541
      I decided to play around with Blender for making a preview of my Submarine in it's final color scheme. Still lots of work to do on render quality and modifications to textures but this should at least get me a better feel for what it will look like on and under the water once complete and let me work on refining the color palette.
      I am also coming to the strong understanding that weathering is an essential feature of boat paint jobs. Without any weathering this boat looks sort of like a machined part that just came off a lathe and I definitely think I need to get some iron rust, bronze tarnish and copper corrosion on there to give it a little bit more of a realistic look. I am sure this multi-metal design just burns thru galvanic protection zincs like there is no tomorrow.
        • Aug 2025
        • 35
Name:	effect of weathering.jpg
        I am so glad I undertook this entire texturing / Blender exercise because I am learning all kinds of important lessons about the importance of proper decoration on how realistic the boat looks. Compare the enormous difference between this render with just a little bit of rust on the iron and a little blue/green copper oxide corrosion on the bronze and copper components compared with the previous look. This boat looks way more realistic. If I had not done all of this detailed modelling work first I would have just slapped some metallic colored paint on the boat and called it done and never understood the subtle details of life at sea and what it does to vessels.
          • Aug 2025
          • 35
Name:	hydrodynamic test model.jpg
          I made a small 4 inch long hydrodynamic model to test the drag and how the finished boat would turn and move in the water. No electronics or anything else aboard this tiny bath toy but it gave me some practical experience with the boats final performance. It turns exceptionally well but is kind of a brick in forward motion as expected. It has a slight tendency to nose dive as well. The angle of the forward nose cone more than compensates for the drag of the fins and periscope. So it is the slow and quiet life for this submarine as I expect she would rapidly lose control at higher speeds and tend to bury herself in the mud.
            • Aug 2025
            • 35
            Also she is steady as a raft during wave testing. The static stability is quite incredible and the model tends to self right up to 90 degrees when it starts to flip over and stay upside down, as you would expect given the general geometry of a vessel who's beam is very close to the length.
