Fictional Large coastal SSK
    • Oct 2017
    • 1078
    Greetings! It has been some time since my last post as the construction of our garage=lack of workshop and cold temperatures in our attic prevented me from model building. Yet there is some progress with the SSK: Deck installation done, diveplanes&rudder are installed, residual tape marks removed, drive shaft under construction, engine mount done, major filling done.
ID:	179095 Click image for larger version
ID:	179090 Click image for larger version
ID:	179082 Click image for larger version
ID:	179092 Click image for larger version
ID:	179084 Click image for larger version
ID:	179089 Click image for larger version
ID:	179081 Click image for larger version
ID:	179083 Click image for larger version
ID:	179085 Click image for larger version
ID:	179093 Click image for larger version
ID:	179094 Click image for larger version
ID:	179079 Click image for larger version
ID:	179080 Click image for larger version
ID:	179086 Click image for larger version
ID:	179087 Click image for larger version
      • 13948
      There are so many different materials employed on the hull. This thing will crack like an egg as it cycles through hot and cold environments.
        • Oct 2017
        • 1078
        Haha, it is supposed to have a "used" look.Its weld-glued pvc on pvc. Its resing and glass on resin and glass. I guess only place with possible cracking to be the bow sphere. That thing is held together with screws and bolts and rivets.
        But yes, there are several materials involved, however there was no cracking in between minus 10 degrees and plus 30 degrees that i had outside during night and out in the sun.
        We'll see. Thats a test ship, not a centerfold;-)
          • 13948
          Fair enough. We'll see.
            Jorg,
            Your skills with working with so many different materials on your build is certainly evident! The finished boat will certainly be interesting to see. I like David, really enjoy seeing so many different type of tooling being applied on your build. Your photos are great, keep them coming!
            "Firemen can stand the heat."
              • Oct 2017
              • 1078
              Thank you, Rob! Will do. Certanly intersting if the 775' engine will break down the drive train and if the momentum will roll the boat! Maybe will see more progress tomorrow.
                • Oct 2017
                • 1078
                Little time during the Easter weekend to spare for the hobby, but i made a support for the stern cone that will align dead center with the engine and the sternward portion of the split driveshaft. Leaves plenty of room for the servos while puttung the engine more to the back of the electronics tray.
ID:	179179 Click image for larger version
ID:	179180 Click image for larger version
ID:	179181 Click image for larger version
                  • Oct 2017
                  • 1078
ID:	179396 Click image for larger version
ID:	179400 Click image for larger version
ID:	179398 Some more work...
                  Construction of the servo tray and milling an end cap for the keel:
ID:	179403 Click image for larger version
ID:	179397 Click image for larger version
ID:	179399 Click image for larger version
ID:	179405 Click image for larger version
ID:	179401 Click image for larger version
ID:	179402 Click image for larger version
                    • Oct 2017
                    • 1078
                    Ready for glueing it all down! Resin filler will close the gaps afterwards, while the port and starbord covers will be removeable to access the stern's "skeleton"
                    Click image for larger version  Name:	20240416_215320_copy_1600x900.jpg Views:	0 Size:	45.4 KB ID:	179432 Click image for larger version  Name:	20240416_215313_copy_1600x900.jpg Views:	0 Size:	42.3 KB ID:	179431 Click image for larger version  Name:	20240416_215352_copy_1600x900.jpg Views:	0 Size:	45.6 KB ID:	179433
                      • Oct 2017
                      • 1078
                      Installation of the pushrods for rudder and sternplanes. Two small openings in the lower stern cone will give acces to the setscrews for fine tuning. Click image for larger version
ID:	181227 Click image for larger version
ID:	181228 Click image for larger version
ID:	181229 Click image for larger version
ID:	181230 Click image for larger version
ID:	181231 Click image for larger version
                        • Oct 2017
                        • 1078
                        The "Kort-Nozzle" propeller guard has been permanently clamped down on the lower stern keel with a clamp from stainless steel. Click image for larger version
ID:	181234 Click image for larger version
ID:	181238 Click image for larger version
ID:	181237 Click image for larger version
ID:	181239 Click image for larger version
ID:	181235 Click image for larger version
ID:	181236 Click image for larger version
ID:	181241 Click image for larger version
                          • 13948
                          You're in for a nasty surprise once this multi-media model suffers the effects of rapid temperature change at the lake/pool.
                            • Oct 2017
                            • 1078
                            I'll send a personal picture with all the cracks, O David my David!
                            Have faith!
                              • 13948
                              Have faith!
                              No. Post 'em here, so everyone can learn. (Checking my blood-pressure... OH, MY!)
                                • Oct 2017
                                • 1078
                                #30
                                Hello everyone! I removed a bellow seal for the pushrods yesterday and to my surprise, it stuck to the brass tube i installed it onto plus the lid to the pushrod had gotten soft and showed a fissure. Somekind alike those silicone soft touch coatings on keyboards etc that turn sticky after a few years or when permanently exposed to sunlight.
                                I had not applied any grease/glue/alcohol, i only srt it up for testing back in '24 and removed it now. Boat was not in the water yet.
                                With that setback, and since i NEVER EVER experienced a bellow seal intact in the first place i am unsure i can use them at all. Maybe i just bought garbage? Really thinking about switching for my usual Engel Seals...
                                Anybody having advice? What brand or vendor should i look for? How do i maintain those seals?
                                Best regards, Jörg
                                PS: still NO cracks, David, even after falling from the bench...
