Fictional Large coastal SSK
    • Oct 2017
    • 1118
    Greetings! Some shots of an old project, a fictional submarine. Designation "Large Coastal Submarine". Objective was to build a hull from mostly prefabricated components from the hardware store around a possibly large battery. I started in 2013. A single hull design with a very large dry compartment, tech rack type. Large wet bow and stern. Pressure hull is a 110mm drain pipe. Mostly pvc, parts weld glued or screwed down. Snort System will be used.
ID:	172823Click image for larger version
ID:	172824Click image for larger version
ID:	172825Click image for larger version
ID:	172827Click image for larger version
ID:	172826Click image for larger version
ID:	172829Click image for larger version
ID:	172830Click image for larger version
ID:	172831Click image for larger version
    Fictional? Looks like a Type 206.
    Click image for larger version  Name:	images (1) (1).jpg Views:	0 Size:	30.7 KB ID:	172834
      • Oct 2017
      • 1118
      Indeed, but i want it to look like the 206' big brother
        • Oct 2017
        • 1118
        Some more work done. lower rudder support has been screwed onto the stern cone. Upper rudder support almost ready for installation. An aluminum bar and a "cheat" propeller shaft help aligning the parts to the cone. Therefore, the hull has been installed upside-down onto the bench. Click image for larger version
ID:	172942Click image for larger version
ID:	172944Click image for larger version
ID:	172943Click image for larger version
ID:	172945Click image for larger version
ID:	172946Click image for larger version
ID:	172948Click image for larger version
          • 14008
          I love watching old tools used well.
            • Oct 2017
            • 1118
            Thank you! I see the rust, need to do something about that. My current garage is not very tool-friendly. Steel walls and metal ceiling. Only good for dry humor...
            It will not survive that year, planning for a proper garage with proper shop and WINDOWS ( I envie your's, David Hughes!)
              • Oct 2017
              • 1118
              The stern has been assembled. Next will be completion of the bow and installation of the deck.
ID:	173138Click image for larger version
ID:	173140Click image for larger version
                • Oct 2017
                • 1118
                Greetings! The bow compartment is basically finished. Ech time glueing makes the boat look like a mummy!I made a new, higher deck for the bow and the main hull instead of using a raised bow, so i can accomodate the snorkel line much simpler. The conning tower is held in place by two stainless M6 threaded rods epoxied all the way through the fwd and sternwd sail portion with two stainless nuts under the deck. both deck portions will be bolted down onto a rail thats been glued down onto the outer casing.
ID:	173460 Click image for larger version
ID:	173463 Click image for larger version
ID:	173467 Click image for larger version
ID:	173468 Click image for larger version
ID:	173466 Click image for larger version
ID:	173462 Click image for larger version
ID:	173461 Click image for larger version
ID:	173464 Click image for larger version
                Jörg
                  Very nice.
                    • Oct 2017
                    • 1118
                    Thank you!
                    Prior to permanently glueing the forward bulkhead to the hull, i prepated the upper deck for installation and disassembled the hull sections to check for proper alignment of the parts. First pictures show the fwd bulkhead that will hold the bow section with radial bolts just like the stern. You can also see the electrobics tray and the stern bulkhead. One large o-ring placed into the rim of the draining pipe will make the seal. Click image for larger version
ID:	173526 Click image for larger version
ID:	173522 Click image for larger version
ID:	173519 Click image for larger version
ID:	173521 Click image for larger version
ID:	173520 Click image for larger version
ID:	173528 Click image for larger version
ID:	173527 Click image for larger version
ID:	173529 Click image for larger version
ID:	173530 Click image for larger version
ID:	173523 Click image for larger version
ID:	173525 Click image for larger version
                      • Oct 2017
                      • 1118
                      Making covers for the maintenance openings.
ID:	173646 Click image for larger version
ID:	173643 Click image for larger version
ID:	173644 Click image for larger version
                        • Oct 2017
                        • 1118
                        Installation of ther stern cone' tip.
                        The cast urethane tip was aligned with the "shaft" / threaded M6 rod punching both through the stern bulkhead and the centering discs inside the propeller guard. Nitrofiller was pushed into the gap between cone and tip.after curing, 6 3mm holes were drilled through and plastic dowels were inserted to hold the tip in position. Now the bilkhead could be removed and epoxy glue, thickened with urethane particles, could be filled in from the inside. More pictures from the drive shaft installation to come.
ID:	173732 Click image for larger version
ID:	173734 Click image for larger version
                          • Oct 2017
                          • 1118
                          More filling on the stern. Hopefully i'll finish sanding all the filled spots this evening and will cast-in the stern tube. To ease work, i dissassembled the sterns maon components. Bow's been filled,too.
ID:	173754 Click image for larger version
ID:	173755 Click image for larger version
ID:	173756 Click image for larger version
ID:	173757 Click image for larger version
ID:	173759 Click image for larger version
                            • Oct 2017
                            • 1118
                            Building the counter-nut for the M6 main setscrew that will lock the stern and the inner tray to the main hull. My preferred modification of the ROBBE design. 2 m5 screws secure it to the forward tray bulkhead.
ID:	173838 Click image for larger version
ID:	173839 Click image for larger version
                              • Oct 2017
                              • 1118
                              This evening i made the sealing disc that will a) hold an O-ring between itself and the outer face of the Bow bulkhead that seals the locking bolt radially and b) acts as a large washer to counter the force of the tightened locking bolt against the bulkhead. A second o-ring will sit between the disc and the smaller aluminum washer, beeing compressed when tightened. 1-2 large cylinder screws , threaded through the forward bulkhead to the inside will slide into corresponding holes in the tray bulkhead to prevent twisting of the frame when locking down the boat.
                              Click image for larger version  Name:	20230919_222611_copy_1440x1080.jpg Views:	0 Size:	57.6 KB ID:	173977 Click image for larger version  Name:	20230919_224400_copy_1440x1080.jpg Views:	0 Size:	57.3 KB ID:	173980 Click image for larger version  Name:	20230919_225514_copy_1440x1920.jpg Views:	0 Size:	57.0 KB ID:	173978 Click image for larger version  Name:	20230919_230722_copy_1440x1920.jpg Views:	0 Size:	59.8 KB ID:	173976 Click image for larger version  Name:	20230919_230806_copy_1440x1920.jpg Views:	0 Size:	49.1 KB ID:	173979
