Water proof Servos and motors.
  • Halcyon66
    • Oct 2021
    • 28
    Quick question has anyone experimented with water proof servos and motors? Thus limiting the WTC units to RX's and pump systems and some water proof connectors.
    Regards,
    Gregory
    • 1777
    Yes, extensively. I and many others have successfully waterproofed standard servos, and I've used the new "waterproof" Hitec servos to good effect as well. Brushed motors can run wet, though they require additional maintenance and the life will be reduced. Brushless are perfectly happy in the wet, but again, you have some post-run maintenance for a full lifetime. My new cylinders feature brushless in the wet.
    As a point of thought, you've eliminated a linkage seal, but now you need to deal with an electrical seal. Certainly doable, but bear that in mind.
      • 803
      I do it on most of my boats.
        • 2752
        Check out Bob's video on how to make a waterproof servo.
          • 2752
          How to waterproof your electronics.
            • 2752
            This guy doesn't even use a WTC. He just seals his electronics with nail polish.
              • 12309
              Stunning work!
              • Halcyon66
                • Oct 2021
                • 28
                Great replies, many thanks. Been using the big hitec waterproof on some other projects yet good to know others are as well.
                Regards,
                Gregory
                • SubDad79
                  • Dec 2021
                  • 9
                  I've used this product on my truck servos, receivers and LED circuit boards to waterproof them
                    • 2752
                    https://jimsbearings.com/products/he...erproofing-kit
                    Looks like nail polish.
                    • RanSan
                      • May 2020
                      • 61
                      I guess the next question is for those who use motors in the wet what is your typical post run maintenance?
                      In your book Bob you mention the brass rod through the bulkhead for the servos would that method work for the motor or is the current to high?
                        • 1777
                        Randy,
                        That would work just fine, but typically use bullet connectors embedded in the end cap. That way you can just unlplug the motor to completely remove it for replacement, maintenance or upgrade.
