Looking for photos of internal layout of 2"SD for Type VII
    As I posted before I acquired an unbuilt 1st generation RCABS wtc designed for the Revell 1/72 Type VII. It's composed of 2 6" length x 2" dia. clear tubing and a 3" length of 2.75" dia. section. The 2 6" sections are connected by a double ended endcap with a central cutout for the wires and tubings. My plan is to convert it into a gas/snort system. Want the scale waterline trim look.
    Can you please post photos of the Type vii wtc so i can get an idea how to fit everything inside the 6" sectio.
    Thanks.
    • 13983
    So.... let me get this straight: you bought one of those POS 'experimenter's kit' WTC's from a competitor? And you want me to bail you out with instructions??
    BWAHAHAHA!!!!
    OK, I'm OK now.
ID:	90414Click image for larger version
ID:	90415Click image for larger version
ID:	90416Click image for larger version
ID:	90417Click image for larger version
ID:	90418Click image for larger version
ID:	90419Click image for larger version
ID:	90420Click image for larger version
ID:	90421Click image for larger version
    Wiping tears of laughter from my eyes.
    Next time, don't play it cheap. Play it smart.
      Think of it as consulting the great oracle...
        • 2641
        Finish your kilo!
          • 13983
          Finish your kilo!
          YEAH!!!! .... what he said!
          Join the ranks.
          • crazygary
            • Sep 2012
            • 610
            Geez!! That is one "kickass" SD!!
            Is that bad boy for the 1/144 Kilo?? (Which'll be my next build!)
            CG
              • 13983
              What I presented were 1/144 SEAWOLF and 1/144 KILO 2" SD's. Only real difference between them is cylinder length, ballast tank volume, and motor size -- other than that they both are representative of typical device layout for that diameter cylinder.
              All SD's with the exception of the 1.25's and KILO's are SAS equipped.
                Finish your kilo!
                Yes. Got momentarily sidetracked by old hobby
