Looking for photos of internal layout of 2"SD for Type VII
    • 3592
    As I posted before I acquired an unbuilt 1st generation RCABS wtc designed for the Revell 1/72 Type VII. It's composed of 2 6" length x 2" dia. clear tubing and a 3" length of 2.75" dia. section. The 2 6" sections are connected by a double ended endcap with a central cutout for the wires and tubings. My plan is to convert it into a gas/snort system. Want the scale waterline trim look.
    Can you please post photos of the Type vii wtc so i can get an idea how to fit everything inside the 6" sectio.
    Thanks.
    • 13792
    So.... let me get this straight: you bought one of those POS 'experimenter's kit' WTC's from a competitor? And you want me to bail you out with instructions??
    BWAHAHAHA!!!!
    OK, I'm OK now.
ID:	90414Click image for larger version
ID:	90415Click image for larger version
ID:	90416Click image for larger version
ID:	90417Click image for larger version
ID:	90418Click image for larger version
ID:	90419Click image for larger version
ID:	90420Click image for larger version
ID:	90421Click image for larger version
    Wiping tears of laughter from my eyes.
    Next time, don't play it cheap. Play it smart.
      • 3592
      Think of it as consulting the great oracle...
        • 2546
        Finish your kilo!
          • 13792
          Finish your kilo!
          YEAH!!!! .... what he said!
          Join the ranks.
          • crazygary
            • Sep 2012
            • 610
            Geez!! That is one "kickass" SD!!
            Is that bad boy for the 1/144 Kilo?? (Which'll be my next build!)
            CG
              • 13792
              What I presented were 1/144 SEAWOLF and 1/144 KILO 2" SD's. Only real difference between them is cylinder length, ballast tank volume, and motor size -- other than that they both are representative of typical device layout for that diameter cylinder.
              All SD's with the exception of the 1.25's and KILO's are SAS equipped.
                • 3592
                Finish your kilo!
                Yes. Got momentarily sidetracked by old hobby
