Looking for Cabal report Trumpeter Kilo Build
  • george
    • Dec 2010
    • 731
    Hello
    I looked through the section BUT there is No Cabal Report that covers the full build of the Trumpeter 1/144 Kilo build, just a few bits. Is there a full build?
    George
    • 13980
    Originally posted by george
    Hello
    George
    Go to this site and look up, 'r/c'ing the Trumpeter KILO'. Not much useful information I'm afraid as that job involved a now discarded 2.5" diameter cylinder. But good for showing how to punch out the bottom flood-drain holes.
      Have you seen these?
        • 13980
        Romel to the rescue! Thanks, friend.
          http://vabiz.com/d&e/articles.html
          I thought I'd copied all those vabiz files and converted them to pdf files, then loaded them to the Caswell database. I'm pretty sure I didn't miss any, or did I?
            • 3753
            I have read these cabal reports at least twice before, and just read them again great information. I learn more each time I read them!
            David do more please!
              • 13980
              Mike is so right, he did work all those old Cabal Reports (the relevant ones) into proper PDF format, and some time ago. And, as Romel pointed out, they are on the site, ready for down-load. Mike put a lot of time and care, and I was remise in forgetting that they were already there ... sorry, Boss.
              I wish I had the time to compose new Cabal Reports, but I'm so behind in work .... two long promised WTC's for Mamas, a completed submarine for our Moderator, a little 1.25" SD for Gene's 1/72 Type-A, and the list of delinquent things goes on. Once I'm caught up I intend to reduce recent work to full blown Cabal Reports that should be useful to anyone in this game.
              Time is the missing ingredient -- I blame Mr. Caswell and his crew, they keep hitting me with Purchase Orders.
                There is one useful thing David forgot to include in his cabal report. It's about the stern cone. You'll need to cut off about 3mm from the tip (or you could just eyeball it to match the diameter of the propeller hub.) Next you plug the end with tape, stand the sub on it's tail and fill the inside with baking soda and CA to create a plug. You then drill it out using a 1/16" drill bit to accept your shaft.
Name:	Stern cone bushing.jpg
                • george
                  • Dec 2010
                  • 731
                  Hi redboat219
                  Please excuse my ignorance but could you explain the 1/16" drill bit for the prop shaft? I didn`t know that there was a 1/16" prop shaft on the market for the kilo? Don`t you use a bearing in the end of the submarine for the prop shaft? How do you make sure the hole is centered there?
                  Thanks for the help.
                  George
                    The 1/16" shaft comes with the fittings kit for the kilo. Without the bearing/bushing the prop shaft has the tendency to wobble in the stern cone.
                    About making the hole centered I just eyeballed it. You could always replug it with Ca and redrill.
