Looking for Help
  • george
    • Dec 2010
    • 731
    Looking for Help
    Hello
    I have a trumpeter 1/144 Kilo submarine that I want to turn into a static diving R.C submarine. My question, is there anyone out there who has a template / pattern of where to cut out the flood holes on this submarine, their location and size?
    Even pictures of one already done and working, from All sides, would help, as well as the flood hole sizes.
    Thanks for the help.
    George
    • 13610
    Originally posted by george
    Hello
    George
ID:	82920Click image for larger version
ID:	82921Click image for larger version
ID:	82922Click image for larger version
ID:	82923Click image for larger version
ID:	82924Click image for larger version
ID:	82925Click image for larger version
ID:	82926Click image for larger version
ID:	82927Click image for larger version
ID:	82928Click image for larger version
ID:	82929Click image for larger version
ID:	82930Click image for larger version
ID:	82931Click image for larger version
ID:	82932Click image for larger version
      • 3454
      I used a drawing of the Kilo I got from another site. Click image for larger version
Name:	Kilo Plans.jpg
      Printed it and had it enlarged to the same size as the model. Click image for larger version
Name:	Flood holes location.jpg
      I then aligned the hull with the drawing and marked out the locations of the flood holes. Click image for larger version
Name:	Flood Holes Drilled.jpg
      You may want to place your further out from the centerline.
      • george
        • Dec 2010
        • 731
        Hello redboat219
        Thank you for your help. Can you tell me after you printed out the first plan, what enlargement Percentage did you use to get it to be the same size as the Kilo? If I understood your post, first just print out the plan you posted then enlarge it at a print shop???
        Please confirm and explain for "slow" person like me.
        George
          • 3454
          Yes print it out and have it enlarged by 206%.
