Take a look at this site and you'll see this company selling a paper model of a couple of submarines.
I first spotted someone making a model from paper over at the SC site . However, I wasn't too impressed with the way he was doing the job.
Here's what I think should happen.
Anyone game? (I'm too busy!)
- Buy the plans.
- Take them to Office Max and get them blown up to scale at 1:72 (They are currently 1:200). The HMS Astute model will be 53" long.
- Mix up some epoxy (slow cure) and add 50% lacquer thinner to it, then dip the paper in it, let it soak through, then hang it up to drip dry and cure overnight. The paper should then be fairly stiff but still flexible.
- Cut out the parts and build the model.
- Cut it along the waterline, Z bend, whatever your preference.
- Lay up some thin fiberglass cloth inside the hull, then continue to build up layers of chopped strand matt to a satisfactory thickness.
- Sand down the exterior and fill voids, lines etc with Bondo etc.
