Retracted masts on a Virginia class sub?
  • Timothy L
    • Sep 2024
    • 205
    I am looking for a photo of the sail on a Virginia class sub with all masts are retracted. I have searched - but to no avail.
    Extended resin masts on a 1:72 sub seem highly susceptible to damage. I could scratch build more robust masts but first I would like to explore retracted masts - might be kind of different and look cool but not sure.
    Thank you.
    Tim
    • 13890
    Thank you.
    Tim
    A bit complex for you at this point in your 'journey', Tim.
    How about removable masts? Easier, and gives you the option to run the boat with, or without them. Here are some examples:
    • Timothy L
      • Sep 2024
      • 205
      Got it. Thank you David - very helpful examples which will help me find a practical approach (kinda wish I had a lathe but can’t happen right now ;-)
      • Timothy L
        • Sep 2024
        • 205
        David - are most of your sails removable for ease of transport? Thank you.
          • 13890
          Get a Taig lathe. Won't put you out too much.
            • 13890
            All but the Soviet boats (the Rubin design bureau boats an exception) feature removable sails.
            • Timothy L
              • Sep 2024
              • 205
              Thank you David. Almost every building decision I head scratch over occurs overnight while sleeping. I love waking up with a clear direction LOL. The sail will use fabricated metal masts and be removable. Onward!
              • Ken_NJ
                • Sep 2014
                • 1001
                David, can you repost additional pics of the process for this one? I get the jist of it, I like the precision and detail of such a small and complicated part. D0 it in your 'today's work' if you want.
                  • 13890
                  Excelsior!...
                    • 13890
                    Ask and ye shall receive, Party-Boat Boy!
                    • CC Clarke
                      • Aug 2020
                      • 313
                      Having a full set of masts imports flexibility in your build options.
                      A set of 1/72 masts printed in ABS-like resin are pretty tough, and the more expensive engineering resins are even more durable.
                      When building custom boats, I print the sails with all mast openings clear, then insert a raised or lowered version to fill the openings. Generally, the periscopes (two types for the 774 class) are the only raised masts, but the customer gets the final say. A dab of RTV to the bottom of the masts allows easy replacement if required.
Name:	Rev 4 Ortho Perspective.jpg
                      This is a current full set of masts as carried by the Block IVs.
                      CC
                      • Timothy L
                        • Sep 2024
                        • 205
                        Although I’ll fabricate the masts, I won’t aspire to the level of detail and quality so masterfully demonstrated by David ;-) For one thing, I don’t have the skill set - but I also lack a lathe. My saving grace is that I normally aspire to a level of detail that 1) is durable and 2) is viewable / realistic at a minimum distance of perhaps 6’ from water’s edge. I’m not a rivet counter and I don’t like things to break. I like to operate. Just food for thought.
                        For example, here are photos of my San Pedro and Nancy L tugs plus a the real tug that inspired the heavy rusting on Nancy L. The detail on the tugs have two things in common. First, The detail is not designed to be examined from 12 inches - It’s created to have a realistic look at several feet from the water’s edge. Second, There are some things that I enjoy or have fun with that are not necessarily on the real vessel. Rather, it might be just something fun that I like to see on a vessel (ie creative license). I tend to agree with Frank’s approach: it’s my boat and I’ll do what I want LOL.
                        My Virginia class, as another example, Well on the surface will be able to play a variety of Music: Ranging from Navy versions of anchors away to The Andrews Sisters. Does that have anything to do with realism? Nope - But it’s an aspect of modeling that I just happened to love!
                        The San Pedro
                        Click image for larger version  Name:	IMG_3834-compressed.jpg Views:	1 Size:	77.4 KB ID:	195270
                        The model Nancy L
                        Click image for larger version  Name:	0u1a0152-compressed.jpg Views:	1 Size:	91.8 KB ID:	195271
                        The real tug.
                        Click image for larger version  Name:	IMG_0472.jpg Views:	1 Size:	36.3 KB ID:	195274
                          • 13890
                          The San Pedro
                          The model Nancy L
                          The real tug.
                          Love the rusting.
                          All figures need to be finished with a flat, flat, flat clear-coat. Unless it's wet leather or a sequined dress, figure flesh and clothing are presented as non-reflected FLAT!
                          You people!...
                            • 865
                            Masts are very important from a visual sense too, they provide detail and scale to the rest of the sleek clean sails and hulls very often. I usually make mine removable and can do mast 'flower arrnging' if I want to practice periscope depth keeping, I will have just an attack scope up and the rest down or not inserted.
                            David, can you if you remember the paint colors or formulas for the grey blue and black? Primarily the blue please? Its (of course perfect!) I read the camo then in that period was a grey shade same tone, for Atlantic fleet boats, and a grey blue for the Pacific fleet boats. Correct?
                            • Timothy L
                              • Sep 2024
                              • 205
                              I agree 100% - they actually are flat - but the photo conditions made a bit of a gloss look. Nothing more ridiculous than glossy figures!
