Udate on work inside the cave
    • 1651
    It has been some time, but i need to give you guys a update on what's going on, lost my loyal hairy CO after 17 years of sevice, unfortunally that's live, but she left a hole in my life.
    Done some mayor things on the type XVIIb, took the effort to loose some weight on the upperdeck by griding her down, made some modifications on the float valves to make this construction lighter, changed the mechanism to steer the strange frontwing and the locking mechanism of the upperdeck, pretty much the same story on reducing weight above the waterline.
    Also made some changes on the deck which holds the lexan hatches, there was a tendency to keep water on this deck, so the boat sat lower on the waterline after a dive, removed as well at the front and the back the obstructions to discharge the water.
    Took the V80 apart to hunt down some leaks, re-glued the complete frontpart and made some changes in the wiring, not a lot of work but getting things out goes quick, rebuilding everything takes some more time.
    Re-did the SD which i'm using for both the V60 and Ko Hyoteki, had some cracks in the SD, which where glued shut and changed some O rings, replaced the ADF for a new one and rebuilded the inside, she underwent some rigourus testing in the testpool to check everything is watertight.
    Last thing i did trimming the boats, V80 is done and ready for patrols, V60 took some more lead and foam to get her right and retrimming the Ko Hyoteki, pretty much the same story, the rearpart turned out to be lighter, so removing some foam fixed that.
    For now i'm fighting the XVIIb, since this a dry hull boat i have to shift some lead inside the ballasttank to get her upright, this proces has to be done step by step, adding foam will be the last step, this has to be done before the end of this month, there will be a meeting in Germany which i want to attend, the event itself will be three days, so i'm looking foward to it.
    If you guys want some pics on the work i've done, just ask.
    Started to build me a SD from scratch for the little Kilo sub, which is still gathering dust inside the box, i'll start a building thread on the progress sofar.
    I'm incredibly sorry for your loss.
      • 1651
      Thanks Romel, i know she was just a cat, but you get attached to her, she had a good live with up and downs, i still have one hairy gritter left, she doing well dispite the loss of her big sister.
        Manfred,
        Whew! I totally misunderstood you. When you said CO I thought you meant your wife.
        Did find it odd calling her 'hairy'.
        Still, sorry about your cat.
          • 1651
          I did read that between the lines, so i needed to give a better explanation, my wife is called SWMBO.
            What a coincidence, mine too.
              • 13982
              Started to build me a SD from scratch for the little Kilo sub, which i still gathering dust inside the box, i'll start a building thread on the progress sofar.
              Welcome back, old friend.
                Very much interested in seeing your scratchbuilt SD for the tiny Kilo.
                  • 1651
                  David, never been far away, watched your latest work with interest, there is always something to learn.
                    • 1651
                    Only have the tube left, the rest was cannibilised in the past, have to rebuild all the basic stuff
                    Manfred
                      • 3757
                      Manfred, I am sorry about your feline buddy passing away. They do have a way of stealing a chunk of our heart. Mine are canine, but still they are family. Always want to see what you are doing, so when you are willing, please share. Good to see a post from you.
                        • 1651
                        Thanks Tom, tomorrow i'll take some pics about the progress, be patient.
                          Manfred,
                          losing a pet is incredibly sad. I love furry animals better than most humans, as they aren’t judgmental, and always show unconditional love. I found a cat once, and in 15 years, he was by far, a great pet, that even helped raise a few dogs. My condolences, and I look forward to your future posts.
                            Manfred,
                            You are what the Japanese call a "Takumi". A master of precision thinking and practical tinkering.
                              • 1651
                              Romel,All i can say is HAI!!,
                              As promised some pics i took today, had to test the XVIIb anyways, this was not a succes, have to shift back some lead inside the ballasttank, she's now listing to the other side, so back to the cave with her.
                              Pics from the trimmed Ko Hyoteki type B, using the same SD as with the V60
                              Same story with the V60, she is trimmed with the hatch open, you have to take in account that airbubble inside, if by accident the hatch will open she won't take the trip to the bottom, due to David's SD configuration you can trim both boats without using the transmittor, simply turn the boat around to fill up the ballasttank and shake her to get all airbubbles out.
                              End of session trimming the boats, that SD preforms very well and i can use for both boats, the type XVIIb is on the bench, yet to be opened to shift some lead.
