U.S. sub sinks Iranian warship
    I always thought these torpedoes are supposed to hit
    mid ship, not the engine room. But apparently here it doesn’t matter. I have read a lot about these torpedoes, and the fascinating thing about it is, if they miss, they can turn around and try again. Amazing that they have miles of wire they can use. God bless our troops.
      Originally posted by Das Boot
      I always thought these torpedoes are supposed to hit mid ship, not the engine room.
      Passive acoustic homing
        • 13980
        Active/Passive. So, so many options (preset in the tube or commanded via wire) as to search pattern, speed, search mode, target hit point, etc.
        • Ed Kirk
          • Dec 2025
          • 91
          Mercy for the Iranian sailors, Looks like a near miss aimed at the screws and stern to give them some time to sink slowly and abandon ship.
          • CC Clarke
            • Aug 2020
            • 318
            The MK-48 is optimized for hunting high-speed, deep-diving submarines that have the ability to move through the ocean's thermal layers to hide their noise. Sinking a surface ship with one is about as easy as it gets. The days of contact exploders ended a long time ago. Being wire-guided, a 48 can be steered to detonate wherever the fire control system commands for optimal kinetic effects.
            Lifting the stern the way it did broke the keel, which is the best way to disable/sink a warship.
            There has been a lot of debate online regarding the ship not stopping to pick up survivors by people who have no clue how small an SSN is. Those lucky enough to survive were quickly picked up by nearby ships.
            US submarines rarely rescued survivors in WWII. The Japanese and German submarines forces were no different. War is hell -even when undeclared. The smartest move for any surviving Iranian warships is to stay home, safely tied to a pier. None have a sporting chance with an apex predator of the sea - just like during the Falklands war. The Argentinian fleet went straight to port after the General Belgrano was sunk.
            • CC Clarke
              • Aug 2020
              • 318
              Official confirmation of the Charlotte making the kill. Two war shots expended; the first 48 missed.
              US Navy Submarine USS Charlotte Fired Torpedo That Sank Iran's IRIS Dena: Report | World News - News18
              • SubSteve
                • Apr 2022
                • 143
                "Missed", seems unlikely.
                  • 13980
                  What little I know of 'operational' use, a miss of this wonder weapon is an unlikely event.
                  Back in the day I was involved with the evaluation of the MK48 by two competing contractors'; Westinghouse and Gould (Gould won the contract) back in the late 60's at the Canadian ranges; those prototype weapons, even in their childhood development period, both types were getting in consistently good exercise runs. The weapon, now with about fifty years of modifications, can't help but be more reliable and effective.
                  A miss? Maybe. A broken guidance wire, bum pre-sets, surface capture (primary use of this thing is in deep water after all), bad solution, or out and out mechanical failure.
                  • wlambing
                    • Nov 2020
                    • 398
                    The officer on the MK 113 tends to oversteer these things by alot! Watched quite a few egos cause missed shots in my time on the fast boats! The sad thing is, they keep getting promoted!!! LET THE WEAPON DO IT!!!
                    • Davjacva
                      • Nov 2022
                      • 408
                      Yes, this was Steve Mayou's and my old boat. I'm a plankowner in fact. A lot of misinformation about all of this and the weapons. They were ADCAP MK-48''s. They detonate either by contact/ influence/ or both (select 'C' on the Mk-21 exploder). They are wire guided, but don't have to be (you can shoot and forget, in fact you can cause problems by steering it all the way), these may not have been, but probably were. Neither of the torpedoes 'missed'. The engagement would have been a horizontal salvo and directs one to go one way, and the other in case the target tries to escape. One of them is going to catch the towelhead's ****-barge that undoubtedly has some sort of sonar. For a surface contact it's going to be a horizontal spread that is below the layer, then it will pop up and commence it's search pattern above the layer in passive until it acquires the target, then it goes active continously. For submerged targets, it's much more complicated as you're trying to keep up with where sonar says it is, then run them above or below the layer. It's supposed to position itself mid-ship in order to lift it out of the water and break it's keel. Fun-facts: The Charlotte (5th-flight 688-I) was the first to receive the AN/BSY-2 system, and it had the most mods of any 688 (flights 1-6) except the Greenville which had one more. I heard a while ago, that subs were going to take back on Harpoon or Tomahawk 109-B's for anti-shipping which were all removed around 1990 for some odd reason. That may be the fire, but doesn't make sense unless they just wanted to let the dumb goat-f*&^ers die tired. There's more but you all get the idea.
