A crazy idea that won't go away
  • oztruck
    • May 2010
    • 317
    The control linkages and prop shaft are run through the base of the container which is of a good thickness. I have used the "Caswell" push rod seals for the linkages and a stuffing box for the prop shaft. They are all held in place with some silicone tube and epoxy.
    The lid of the container holds the 2 air hoses for the remote ballast system.
    I am using an old, cut down 9 volt cordless screw driver for the power plant. They have a good motor in them and a strong rotary reduction gear box
    The motor/gearbox, receiver, switches for the pumps, ESC, on/off switch, servos and 12 volt LA battery are all sealed inside the container and so far it seems very water tight
    This is how I plan to install the 2 plastic containers inside the boats hull
    Next step is to trim the boat then detail and paint
    • londondrivingschool
      LoLz.. thats crazy talk =D
        • 2762
        Where will you get the air for blowing ballast, through a snorkel or from inside the wtc?
        This seems to be a good application of David's new Semi-aspirated ballast system.
        If with a snorkel only you'll need an awfully long one in case she sinks in deep water.
        Maybe you could put the ballast tank off to one side. That way you could make her roll off to one side like a cruise liner. Lol.
        • oztruck
          • May 2010
          • 317
          Snorkel, the only way to to get things to come up.:biggrin:
          • oztruck
            • May 2010
            • 317
            Redboat219 you edited and changed your question after I responded!.
            The idea is to have the stern sticking out of the water just a bit. To me it looks more dramatic than not being able to see it at all. When ever you see photos of a sinking boat they always have something sticking out of the water. The cruise liner is sitting on the rocks, that is why it is on its side. When I get a chance I will post a video of it sinking at our pond.
              • 2762
              Hi. Sorry bout that. When I was edited my post you still hadn't posted any reply yet. Check out the time, there's around 7 minutes between our post. What must have happened was I didn't click the save button right away coz I was busy doing something else. Even now I want to edit it coz my phrasing is wrong. Lol!
              Anyway, please post pics of the sinking. Too bad you couldn't simulate her being hit by a torpedo.
              Would having a simulated hit ( say a small electrically fired firecracker or a blast of compressed air) out her side also count as illegal?
                • 12359
                **** Brenner, years ago asked me to come with a means of generating a water plume that would render the effect of a close aboard underwater explosion. He had built up a 'sinking' battle-ship that employed one of my WTC's to control, power, and sink it -- just like a submarine.
                My partner in crime, Kevin Rimrodt and I produced a servo operated 'firing valve' from a Schrader valve that squired propellant liquid into a firing chamber that contained a small amount of water. The methane-butane, mixing with the warm water, would immediately expand to gas, throwing the water, now pretty much a vapor, high into the air. **** installed our device into the model and uses it to simulate a torpedo hit, at which point he would command the WTC to vent the ballast tank, and down would go his battle-ship. Either through transmitted command, or automatic operation of the fail-safe, the WTC's ballast tank is blown, and up comes ****'s Battle-ship, ready to operate with the fleet again -- risen from the grave.
                The device is set into the hull so that the base of the firing chamber is just below the waterline (a small hole in the side of the firing chamber permits water to enter. All that is needed is a shot of propellant to generate a loud 'Whoosh' sound accompanied by a magnificent plume of water. Kevin demonstrates here. Noet that **** built the deck as an open mesh -- this to permit quick venting of the hull as the WTC floods, dragging the hull to Davy-Jones' Locker.
                ****'s battle-ship outfitted with its WTC. Note the many large holes punched through the bottom of the hull to aid in flooding and discharge of water.
                **** at the lake, ready to launch his sinking battle-ship. **** does it all: a frist-class Machinist, Kit producer, contest flyer, Jeweler, etc. And all round, Good-Guy! These shots were taken May, 1995
                • Pablo
                  • Jul 2010
                  • 47
                  Hi everybody!
                  I do'nt know if it is the right place to post this, fell free to move if necessary.
                  A good friend of mine built 2 models for an animation scenario he presented in a recent regatta.
                  1/ A Robbe U-BOOT TypeVII modified with ballast and torpedo launching.
                  2/ A scratch made cargo boat fitted inside like a sub.
                  Story is supposed to take place in North atlantic ocean in 1941 /1942. Cargo is sailing at low speed when the U-Boot surfaces and fires 2 torpedos.
                  When a torpedo hits the cargo, water spatters upward (pump), the front mast falls down and the cargo begins to sink. When it goes to the bottom, a rowboat remains on-surface.
                  Inside of the cargo boat
                  The wreck of the cargo boat
                  I can't post the pics with direct link because they are too big.
                  The complete pics set of the regatta :
                  My personnal website : http://www.loubet-modelisme.com
                    • 12359
                    Most welcome at this thread. Right on topic. And the level of Craftsmanship ... outstanding. Great stuff.
                    • oztruck
                      • May 2010
                      • 317
                      David and Pablo thanks for the input. David that is a great idea using the gas, I wonder if there is a liquid gas that turns to smoke(vapor)when it comes into contact with water. I could then use 2 outlets, one on the side of the sinker and the other inside the hull. With the smoke inside and as the boat sinks the water pressure would push the smoke out of all the openings. It would look great. Luv this hobby.
                        • 2762
                        Cool Toy!
                        A battleship and submarine rolled into one. I'm amazed by your ingenuity.
                        Any other cool stuffs you got hidden in the back of your cave?
                        • Pablo
                          • Jul 2010
                          • 47
                          Hi!
                          Here are some pics from a 2010 reggatta in Kaiserslautern Germany, the model is a WW1 german battleship.
                          Fitted with ballast it "sinks"
ID:	66428Click image for larger version
ID:	66429Click image for larger version
ID:	66430Click image for larger version
ID:	66431Click image for larger version
                            • 12359
                            Tons. I did a lot of effects work. Some for movie and TV productions, in the days before CGI
                              • 2762
                              Didn't you do the effects for Crimson Tide/USS Alabama starring Denzel Washington?
                                • 12359
                                #30
                                I contributed to the production, yes. I designed and built all the propeller masters and had a hand in the design of the AKULA and torpedoes.
                                Enough chit-chat, redboat219 .... FINISH THAT DAMNED KILO!!!!
