XT60 Connectors difficult to plug and unplug
  • biggsgolf
    • Jan 2020
    • 1036
    Any tricks? I was going to use dielectric grease, but read it does not conduct electricity
  • neitosub
    • Nov 2021
    • 163
    You can try sanding the vertical surfaces of the female plug a little bit.
      • 2639
      My Dad used to have problems with these and Deans plugs as his grip wasn't as good as he got older. He used to bond on bits of leather to bulk out the connector and give his fingers something a bit more to grip on. If you have a printer there are things like this https://www.thingiverse.com/thing:5332396
      Also this which looks like a partial copy of the Turnigy easyoff item https://www.thingiverse.com/thing:1721130
      Not sure how well the pliers will hold up in use though.
      • biggsgolf
        • Jan 2020
        • 1036
        Thanks, will print them out and try! Also was reading that there are different quality XT60's, not sure how to find top quality ones?
          • 2639
          Not hand any issues. I only have a few though, mostly I use Deans and JST's for small stuff, I know some don't like them, but I've always found them fine.
            When you are soldering an XT60 connector, have it plugged in to another (unconnected) connector of the opposite type. This helps it keeps its shape while it gets hot.
            • biggsgolf
              • Jan 2020
              • 1036
              So, I figured it out. I use Spectrum Smart Lipos so discharging is automatic. The batteries have IC connectors.
              • Rick Teskey
                • Jan 2009
                • 265
                Squeeze the bullets (male) in the plug
                • biggsgolf
                  • Jan 2020
                  • 1036
                  thanks, will try that
                    Bear in mind that depending on where you got them, they may not be "brand name" XT-60s. There are cheap, nasty versions out there with sloppy tolerances. Proper connectors should be very easy to make up and break apart.
                      Anderson Power Poles are an alternative you might think of. They’re easy to connect and disconnect You have to have a special crimper, but once you have it, you’ll always use it. But like Bob said, if you’re going to get the ones you’re looking at, get name brand. The ones on Amazon are garbage.
