How I start a New Year!!!!!
    • 13630
    Fire is out, Reflash Watch is set, all compartments ventilated, Class Charlie fire report pending.
    Material loss: one charging unit; one 11.1-volt Lithium-polymer battery; one pair of soiled shorts; and one expended dry retardant fire extinguisher.
    Secured from Fire. Time for my hideous evening salad. Ellie missed one hell of a show.
    Lesson learned: Never leave the shop while charging one of these Chinese made chemical bomblets!
  • vital.spark
    • May 2010
    • 307
    Thank God Dave, you are safe and only minimal damage!
      • 3471
      Whew!
      Someone up there really likes you...
        • 13630
        Whew!
        Yeah... she likely had a hand in this thing going the right way.
          • 3471
          Not yet. Still enjoying some me time but get ready when you get here...
          +*#♤@$×>&$@× " I leave you and you try to burn the house down!!!"
            • 1532
            David, glad you're OK, lipo batteries are pure chemical bombs when not propper used, i guess in your chase you had a bad produced one, in the past i had some puffed one's inside my torps, glad i have the procedure to check them on a timely base otherwise i had a burned out underground cave.
            Question, was it a new Lipo?, or was the charger going wild on this one.
            Is that my old 212 on the rafters, if so, she has been properly weathered now.
              • 2503
              Get yourself a.Pyrex bowl,and place any charging batteries in there. You can store them in the same bowl if you wish.
              if the batteries are getting a bit puffy I tend to lower the charging rate to 0.5c or less, I never charge lipo higher than 1c even if the manufacturer suggests higher.
              • DrSchmidt
                • Apr 2014
                • 1331
                David, seems like you git the part with the fireworks, associated with New Year's eve, a bit wrong.....glad nothing serious happened. I like the idea with the pyrex bowl!
                  • 13630
                  LOL. I'm in trouble down the road. I got it coming.
                    • 13630
                    Me too, Andreas. I'll check into Andy's idea today. Good stuff. But, this morning, it's clean-up time in the shop -- only a half-days work me thinks. Film at Eleven!
                    • wlambing
                      • Nov 2020
                      • 384
                      An excellent example of money well spent by the USN on sending guys like us to Firefighter Training and feeding us franks & beans- the ship is saved!!! Still very leery of any battery that has Li in the name. Charging and storage are always on the basement floor slab, clear of all combustibles, and storage is in a battery bag at the same spot. I still like NIMH batteries!
                      Glad all is gonna be well! A bit of field day and you will be golden!! Does it stink like the magic smoke from an overcooked lawn tractor diode pack???
                      Very glad you are ok!!!
                      Take care,
                      Bill
                        • 13630
                        Take care,
                        Bill
                        FET's and diodes have a very pungent 'magic smoke' flavor to them. Lithium and its electrolyte produce Hydrogen Floride gas when burning -- noticeable but not as 'smelly'.
                          • 3471
ID:	185177 Surplus ammo box li-po charging and storage
                            • 13630
                            I store 'em outside the house. Each ammo-box is outfitted with a 'blow-out plug'.
                              • 3471
                              So it's no longer advisable to charge/use this despite the good readings I get with the lipo tester?
ID:	185219 Click image for larger version
ID:	185221 Click image for larger version
ID:	185220 Click image for larger version
