Building the french suffren sna
    • 954
    #76
    Designing and slicing a new added part. A Drive shaft frame brace for Suffren for printing.
    Click image for larger version  Name:	frame.jpg Views:	0 Size:	41.7 KB ID:	190981
    LycheeSlicer
    Click image for larger version  Name:	suffren-drive-shaft-frame.jpg Views:	0 Size:	54.3 KB ID:	190980
      • 954
      #77
      Next morning, 14.5 hours later Volia!
      These frames will be placed aft interlocking the existing hull wall shapes aft of the OTW dive module. The hole for shaft is 11.5 mm, a 1/2 mm added for ease of fit sliding brass tubing of the Raboesch drive shafts sections with bearings.
      It's amazing to think up a custom part, design it in the morning, slice it using Lychee slicer program, printing that day and overnight, and hold those parts in your hand in the following morning. No striations lines discernable visually compared to non -resin printers.
      I hope my modeling will include the best of the old combined with the best of the new. The Any Cubic 3m Max has been working excellent now after a long early frustrating beginning learning about the world of 3d printing.
      Click image for larger version  Name:	997.jpg Views:	0 Size:	46.9 KB ID:	191005
        • 954
        #78
        Shaft braces being trial fitted Fit good.
        Click image for larger version  Name:	sound-rafts-2.jpg Views:	0 Size:	57.6 KB ID:	191008
        Rubber grommets added. A little sound isolation? Hell why not. The dive module will be on rubber mounts too. If I am going to, now is a good time to add such and they are in the shop spare parts box, so why not. Do Koi Fish do Crazy Ivans? LOL. The aluminum tube in bottom photo is not the actual drive shaft, it's just a alignment reference guide.
        Click image for larger version  Name:	sound-rafts-2-grommets.jpg Views:	0 Size:	44.6 KB ID:	191013
          • 954
          #79
          Printed battery tray for a WKDC12-5F Duracell Ultra 12V 5AH battery forward.
          Fashioning a wooden mockup pattern for RTV silicon mold for making three lead keel ingot castings. 9 x 1.5 x 0.6 inches = 8.1 cubic inches x lead density 0.41 = 3.321 pounds each.
          David! Can you tell me or recommend the proper heat-resistant silicon mold making material for casting lead parts please? Important . Thank you in advance.
          Wood pattern here below
          3d Printed Battery Tray.
          Battery to be used -
          After hours looking at Lithium nickel metal hydrides etc....Opting for keeping power source simple. The battery is heavy and need the ballast weight anyways. The OTW 3.5 is very buoyant. This battery is used by many sub drivers in our local group, so ease of logistics and if technical issues ever happen, all are familiar with this battery, just use aquarium sealant to insulate the positive pole. Keeping battery system simple
            • 954
            #80
            Re-designed Battery tray. Gel cell will lay on its broad side now poles up pointing aft. Not a lipo but should be good. 3.1 libs vs a 15-ounce lipo. No fire hazards ever. Keeping it simple. I need ballast anyways.
            Gel cell can be oriented any way that is best. Battery already waterproof as long as I insulate the positive pole with aquarium sealant.
            Keeping battery as low to keel as possible. I could also fit battery upright in hull too, but the top of battery would be above boats surface trim inside so keeping all of battery surfce area underwater whether surfaced or submerged if it makes trimming later simpler.
            Am I over thinking this?
            Click image for larger version  Name:	battery-tray-7a.jpg Views:	0 Size:	53.1 KB ID:	191531
            Click image for larger version  Name:	battery-tray-8a.jpg Views:	0 Size:	51.1 KB ID:	191532
            Click image for larger version  Name:	12-v-5-ah-suffren.jpg Views:	0 Size:	50.1 KB ID:	191533
              • 1100
              #81
              Good size! No, go ahead, that weight as low as possible. That battery tray can slide fwd and back to determine the proper trim?
                • 954
                #82
                Yes. to a limited degree. The OTW Dive Module will be aft of this tray and will take a lot of volume, (buoyancy).
                Using an analog - a friend's OTW Astute (in 1/72 scale) is being used comparing my Suffern building here. Model sizes same as mine in 1/64. He reports his Astute weighs 23.3 lbs. There will be foam added too, but maybe not as much as you might think. I guesstimate at this early stage aiming for the ballpark
                I was looking at water densities, volumes all that etc. online, it's a useful guide and good for general knowledge (Archimedes principles on Buoyancy) BUT all that math can from reading other posts here just creates another rabbit hole wasting time.
                Fortunately, comparisons with other models are a good gage to. The OTW Dive module he uses in his Astute is the same as mine. It is 3.5 inches diameter (88.9 mm) & 28.5 inches (723.9 mm) long.
                  • 954
                  #83
                  Making the Silicone Mold for the lead keel ingots. Making 2 -3 and will see when its trimming time. The wood pattern in a glued mold casting block. Friend Merriman recommended BB TC-5050 and as he demonstrates in his building threads looks like an excellent material. There is even a distributor for the BB's materials in the next town over saving shipping costs. Bob Martin suggested ust about any silicone mld making material would be sufficient. The smallest amount of BJB's TC 5050 is $90.00 a pint. Amazon has a Mold Max 60 for same amount of material for $34.00. I decided on the trying the Mold Max 60. I do not expect t be doing more than one smelting job. Amazon delivered overnight.
                  I used the whole container. I checked by pouring water into the mold to get a sense of the volumes needed as this was a one-shot execution. Ratio is 100 A & 3 B by weight. Will see!
                  Click image for larger version  Name:	mold-1.jpg Views:	0 Size:	55.2 KB ID:	191560
                  Click image for larger version  Name:	mold-2.jpg Views:	0 Size:	52.3 KB ID:	191561
                  Pardon the mess..lol
                    • 954
                    #84
                    Sizing up lead for keel ballast, lead given to me 20 years ago by a sub model buddy, finally will put to good use. Each photo shows 3 lbs. lead.
                    2 mm sheets and other photo small 1/4 once lozenge size weights. Will smelt later when closer to boat trim time for flexibility arranging.
                      • 954
                      #85
                      all the same weights shown above now in their final new forms
                      Lead ingots smelted and cast, glad that's over. scary stuff lead. heat gloves rubber gloves Face masks outside away from house. 2 casts - they weigh 2,4 and 3.2 lbs.
                      The Silicone mold was tough. The second cast I just melted the small ingots with torch in the mold itself.
                      That over, time to put the ballast aside till later and begin assembling the sections and putty sand now. Yay!
                      The two ridges inside on either side of the weights are structural and have holes through their sections the length of the boat for 3/16 Carbon composite 4-foot-long rods.
                      Click image for larger version  Name:	lead-ballast-done.jpg Views:	0 Size:	47.3 KB ID:	191649
                        • 954
                        #86
                        Hull assembly finally. The well-designed hull components by Randy Sanders all falls literally into place. Light tapping to slide in 3/16" x 48" carbon composite rods stingers for longitudinal stiffness down the long tube interconnected sections.
                        The rods ends cut surprisingly easy, like chalk. But are they strong. Wasn't in a hurry took my time, but assembling epoxying, puttying all took just 45 minutes or less because everything was so perfectly aligned from the computer drafting programing.
                        I suggested to Randy the X stern assembly have its own separate hull ring section. This To make the pump jet and internal clevises push rods access so easy now. It can all be preassembled and attached in a single unit
                        Click image for larger version  Name:	1.jpg Views:	0 Size:	42.8 KB ID:	191664
                        Click image for larger version  Name:	4.jpg Views:	0 Size:	48.5 KB ID:	191667
                        Click image for larger version  Name:	5.jpg Views:	0 Size:	92.8 KB ID:	191668
                        Click image for larger version  Name:	8.jpg Views:	0 Size:	48.6 KB ID:	191671
                        Click image for larger version  Name:	11.jpg Views:	0 Size:	43.9 KB ID:	191673
                        Click image for larger version  Name:	13.jpg Views:	0 Size:	46.9 KB ID:	191675
                        Click image for larger version  Name:	14.jpg Views:	0 Size:	53.0 KB ID:	191676
                          • 954
                          #87
                          Lower hull, assembled, epoxied, puttied sanded primed. Same now for upper half. Putty drying. Now to seat and make all the index slots align and snug fit. making a clean straight separating line as close fitting as possible now. See the reactor cooling intake scoops aft? Flank arrays. If I can just stop pausing to stare at her ill work faster. lol.
                            • 954
                            #88
                            Click image for larger version  Name:	suffren prop 3  b.jpg Views:	0 Size:	73.6 KB ID:	191944 Click image for larger version  Name:	274387269-1d2aee7e-58fa-4f76-960b-859522f83b9b.jpg Views:	0 Size:	64.9 KB ID:	191942 Click image for larger version  Name:	3_4.jpg Views:	0 Size:	70.6 KB ID:	191941 Click image for larger version  Name:	suffren prop 3  a.jpg Views:	0 Size:	47.3 KB ID:	191943 Click image for larger version  Name:	DDS 1.jpg Views:	0 Size:	44.7 KB ID:	191937 Click image for larger version  Name:	DDS 3.jpg Views:	0 Size:	42.6 KB ID:	191936 Today, 11:25 PM
                            A new design evolution for Suffern Propulsor. Also beginning a French DDS for Suffern that will be attached with magnets as a display accessory. In 1/64 scale selected fore model (size of my car trunk) fortunately the PVC pipe at the hardware store and its 90-degree elbow joint (40 mm wide) is actually exact size for this DDS in 1/64 scale. This will form a basic shape, then will have designed door hinges and fairings blisters etc. in back and a base to be 3D printed around it.
                            H I Sutton - Covert Shores
                              • 1100
                              #89
                              I suspected it! They use a steam engine!
                              • Akula54
                                • 53
                                #90
                                I can't wait for the files to be available, this model is awesome !
                                (And I have an OTW WTC wich fit perfectly... )
